Author Topic: Joining the ranks...  (Read 991 times)
Offline Dracon
  • Wannabe Old Timer...
« on: May 26, 2017, 06:35:31 AM »
Hello, just wanted to say hi - I picked up a 78 cb750 a couple weeks ago. It doesn't run and needs a ton of work, but it will be a fun project to work on. I've stripped it down to the frame and am detabbing it and then I'll have everything powdercoated. I'm sure I'll ask a bunch of questions, thanks to all in advance!
Here she is - not much to look at:
Offline MD
  • Living in the North Woods overlooking The Lake.
    • MN North Woods
Re: Joining the ranks...
« Reply #1 on: May 26, 2017, 06:58:14 PM »
Welcome from NE MN.  Where you able to turn the motor over with the kickstart before you tore the  bike down?
-MD
1975 CB550F Super Sport;  Lake Superior Circle 1000, 45-90 Saddle 1000, All in Yooper 1000 and SS 2000 in 48 hrs:  1985 GL1200A, MN in State SS1K
Offline Dracon
« Reply #2 on: May 27, 2017, 02:15:24 AM »
I traded for the bike and it was already apart. The owner said it was knocking and he pulled it apart and was going to rebuild it, but decided it was more than he wanted to do.
When I looked at it the oil filter had metal shavings in it and the 4th piston can be wiggled up and down - the others are all tight like they should be. The valve cover also has an odd hole where the oil enters it - the timing chain didn't break so I don't show what could have caused it. Here's a pic:
Offline Dracon
« Reply #3 on: May 27, 2017, 02:16:49 AM »
I guess this is straying from the "introduction" and into a technical discussion - sorry if I should have kept this out of here...
Offline MD
    • MN North Woods
« Reply #4 on: May 27, 2017, 02:40:36 PM »
Your not the first to do so nor will you be the last.
 It does give us more info on the condition of the bike.  You might as well start a project thread since you will be diving in deep.
-MD
