Author Topic: Starter solenoid 78 cb550k help  (Read 590 times)
Offline evopgt
« on: May 27, 2017, 10:51:57 PM »
Ok. Simplified the ?  Which post gets the + battery cable and which post gets the starter cable??
Offline eigenvector
Re: Starter solenoid 78 cb550k help
« Reply #1 on: May 27, 2017, 11:05:18 PM »
Go back and look at the last pic I posted on your original question - you'll see the solenoid wires and from that you can figure out where stuff should go.
As for the harness - the battery post is where you power the harness, the starter side of the solenoid is only active when you're pressing the starter button, so that post only gets the starter cable.
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
Offline evopgt
« Reply #2 on: May 27, 2017, 11:13:42 PM »
Thanks. In dummies terms. Put the positive cable on the wire harness post!!  :D
