Author Topic: What does a breather seperator do?  (Read 2454 times)
Offline Bradyn13
« on: May 28, 2017, 04:58:14 PM »
I was trying to fix a vaccuum leak the other day by installing some new carburetor boots, and while doing that I noticed a bunch of extra tubes that don't seem to do anything.  I found a picture of them on this forum that I have attached.  Can someone explain in depth what these tubes actually do?  I can't find mention of them in my owners manual.  Can I remove them, or cut them short?
Re: What does a breather seperator do?
« Reply #1 on: May 28, 2017, 05:13:02 PM »
IN THEORY it helps separate the oil from the air and the air with or without the oil vapors returns to re-burn. Early emission control. Necessary for function, no. Good idea (in 1977), yes.
Offline evinrude7
  • not a kung-fu
  • something to hüsker
« Reply #2 on: May 28, 2017, 05:13:27 PM »
my guess is it's an emissions thing.  notice it says on bikes after dec 31st 77.  i'm sure someone more knowledgeable will pipe up.
cb750 k6 - ugly
« Reply #3 on: May 28, 2017, 06:13:42 PM »
The engine rebreather has several attributes.
It evacuates gases from the crankcase, such as oil vapor, water Vapor, and piston ring blow by. Water vapor in particular is best removed forcibly from the crankcase, rather than be allowed to languish inside.  The other gases are mostly hydrocarbons, with some debate about whether oil contamination is a concern, or not, for engine benefits.  However, it is very well known that hydrocarbons in our once breatheable atmosphere is decidedly a bad thing for the lungs of all mammals on the planet, and is best burned in the engines combustion chamber.
The vapor separator is primarily to prevent or reduce water vapor condensate from being inhaled by the engine.  Water and engine metals are far less likely to corrode without water ingestion.
Hope this "clears the air".   😷
Offline Bradyn13
« Reply #4 on: May 29, 2017, 08:18:57 PM »
Those gasses would escape on their own though if the tube just vented to atmosphere correct? The only downside is it is worse for the environment.  So the vapor separator is basically a catch can where water can condense and run out the bottom tube, and the air/gasses can go back into the cylinders if I understand correctly. If I remove the system, any ideas on how best to plug the hole that would be in the cylinder head? I'm sure I can find a way to plug the one in the airbox, but the head is a little more worrying.
Thanks for the reply btw.
« Reply #5 on: May 29, 2017, 08:44:28 PM »
That's the dream.  But there is no positive flow or movement with a simple hole to the outside.  Gases can linger and contaminate the oil supply.
I suppose if you did more frequent oil changes the effect would be reduced.
Not entirely, see above.  But, some feel that lung cancer is a rather severe downside.  Not really fair to require everyone else to stop breathing, IMO.
In essence yes.   All the tubes are in fact ducting devices.
Do NOT plug the crankcase hose vent.  It is the only way piston blow by gasses and pressure can be relieved or equalized with the barometric pressure of the atmosphere.  You can blow seals and cause oil leaks.
Most devil-may-care operators just let the tube vent to atmosphere, and/or put a small air filter on the tube to keep crawling/flying critters out of the engine internals.
My opinion is these folks ought to run the tube up to exit at the gauge cluster.  So, they can experience the full benefit of the mods they made.
(Only half joking there.)
« Reply #6 on: May 30, 2017, 07:00:39 AM »
^^^This.
Offline drumstyx
« Reply #7 on: May 30, 2017, 07:17:24 AM »
*sigh* alright TwoTired, you've convinced me, I'll run the rebreather. What sizes are the hoses used?
« Reply #8 on: May 30, 2017, 10:43:29 AM »
My parts lists are 700 miles away at the moment.  But, if fallible memory serves, it's 12 mm.
Offline SKTP
« Reply #9 on: May 30, 2017, 11:05:31 AM »
Sort of on topic...I have always assumed that the oil-tank vent and the case vent hooked into the re breather...but after seeing that diagram, they don't...I ran hose connecting the two...is that wrong? How are those 2 "vents" supposed to go?....I did this (not my picture)
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
« Reply #10 on: May 30, 2017, 11:15:36 AM »
Top of the valve nipple cover goes to the breather at the bottom of the battery tray
From there, the gasses get circulated to the top of the airbox and the moisture drains to the ground along the inner right side of the frame near the swing arm.
The rear crank case nipple is the oil tank overflow inlet.
These should not be interchanged.
Offline SKTP
« Reply #11 on: May 30, 2017, 11:27:38 AM »
I am slow after the long weekend...so that picture is correct. Correct?
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
« Reply #12 on: May 30, 2017, 11:29:23 AM »
Yes
« Reply #13 on: May 30, 2017, 11:31:31 AM »
What airfilter element do you use?
For the 750s, I use K&N.
For the 550s,  I use either the Uni foam or the Honda paper.  My 78 runs better with the paper, I assume slightly more restriction .  The rest don't care.
The 78 has a lower rebreather stand pipe in the box than earlier models.  Still in cold temps and wet humid weather it needs more frequent cleaning as the sponge saturates with condensate.  The telltale for service is the brown mayo showing up on the dipstick.  Time to clear the breather sponge.  Very easy on the 550.  And run the engine hot for 20-30 minutes to vaporize the crankcase water accumulation.  I'd rather the water condensate collected outside the engine crankcase.
I don't think the 750s have that sponge filter, though.  It's a screen isn't it?  Argh, documents 700 miles away.
« Reply #14 on: May 30, 2017, 11:51:50 AM »
@TT...yes.  Its a sponge.  NLA IIRC.
I just trimmed down a standard absorbent kitchen sponge.
« Reply #15 on: May 30, 2017, 01:09:10 PM »
  Open cell foam you can breathe easily though, should work just fine, provided it is oil and gas impervious.  You could put it in some gas to test it.  If it doesn't dissolve, should work fine.
I suppose the thickness should be mentioned.  It should fit the space for it without any compression .
