Author Topic: steering lock removal, '79 650  (Read 1545 times)
Offline pae
    • Phil Edwards CB650 pages
« on: December 17, 2006, 02:00:19 AM »
Sorry, this may be dumb  ::)
I'm guessing that to get the lock out of the head tube (prior to blasting/plating/painting the frame) I have to drill/grind/file the brass head off the pin in picture below? This then releases the washer that's holding the lock in. Or am I missing something really obvious (it's been known  :D )
'79 CB650  .... | ....  XJ600 electric drag racer  .... | ....  T W M C
It takes a lot of practice to sound like yourself
supersport_CB400F
Re: steering lock removal, '79 650
« Reply #1 on: December 17, 2006, 02:03:29 AM »
You also need the key or you have to drill the barrel and get a new lock!
Offline spitfire
« Reply #2 on: December 17, 2006, 04:58:21 AM »
Yes, I found that one out, if you don't have the key don't bother drilling out the brass head, I did only to find out I couldn't get the barrel out. It's now powder coated in.
Cheers
Den
Wirral UK
1976 CB750F1 bought new in 76
1977 CB750F2: Restoration started
1964 BSA A65R: Waiting restoration
My gallery is here: http://www.sohc4.us/gallery/v/members/personal/spitfire/?g2_navId=x5a30f7b6
supersport_CB400F
« Reply #3 on: December 17, 2006, 06:19:23 AM »
Cheers
Den
Strange! Mine came out without a fight once I put a small drill down the keyhole and turned it with a screwdriver I got a new one for 14 quid DSS.
Offline pae
« Reply #4 on: December 17, 2006, 11:29:25 AM »
Well I don't have a key, so I'll be going for the drill it out option as Biffta. Not a lot to lose as it's imoperable currently.
regards, Phil
Offline pae
« Reply #5 on: December 21, 2006, 06:40:25 AM »
Job done chaps. Brass pin came out easy enough with a small screwdriver under the washer a little bit each side until there was enough to grip the head with pliers. I drilled/broke up the barrel after trying to be 'delicate' with it for a while. Sorted, thanks to all.
regards, Phil
