Author Topic: wrong speedometer tach ratio  (Read 1467 times)
Offline aminemed
« on: May 30, 2017, 04:48:56 AM »
Hi
Just a bought an aftermarket speedometer (attached the picture) for my CB 750, and made a big mistake, i ordered the speedometer with the wrong ratio:
instead of ordering a 2240:60, with a ratio 1:4 i've ordered one with ratio 1:1 60mph = 1000 rpm
Cannot return it.
Is there anything i can do to fix this ? changing the cable maybe ?
« Last Edit: May 30, 2017, 04:57:26 AM by aminemed »
Offline Jimray23
    • none
Re: wrong speedometer tach ratio
« Reply #1 on: May 30, 2017, 04:58:52 AM »
Probably have to change the driver. But im just guessing. By driver i mean the gear on the front wheel.
Jim
1979 kz1000b ltd
    stage 3 cams
    pod air filters
    4-1 open exhaust(no muffler)
    full rewire
    dyna-s ignition
    dyna 3 ohm coils
Offline aminemed
« Reply #2 on: May 30, 2017, 08:06:23 AM »
u mean replace it by a 1:1 gear ?
Offline Bodi
« Reply #3 on: May 30, 2017, 08:23:46 AM »
A different ratio front wheel speedo drive - that fits - is not something you're likely to find. Making a new gear set for the original housing - possible, but not for the casual machinist. A machine shop could make them but not for cheap.
There are inline gearboxes to change drive speed but these are made for cars and I expect the fittings wouldn't be compatible, plus -45% is a big change and probably unavailable.
Overall, best to get a speedo with the correct ratio...
Offline aminemed
« Reply #4 on: May 30, 2017, 08:29:56 AM »
well, it means that i'm just going to throw that away.. ! its brand new !
Online calj737
  • I refuse...
« Reply #5 on: May 30, 2017, 08:38:32 AM »
Sell it on and use the partial recovery to purchase your new one.
Offline Scott S
« Reply #6 on: May 30, 2017, 08:40:57 AM »
 The one you have is used on Harley's, I believe. Someone will want it.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Jore
« Reply #7 on: May 30, 2017, 08:49:26 AM »
You could always work out the equivalent speeds with that speedo and make a new face for it, that's what i plan on doing with mine.
1975 CB400F owner
-Having a vintage motorcycle is like having a moody girlfriend.
My 466 build: http://forums.sohc4.net/index.php/topic,146494.0.html
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=1kkcqhnm1kcofb9sp071iqjml4&/topic,60973.0.html
« Reply #8 on: May 30, 2017, 09:45:14 AM »
not fun..if he only use the first 1/4 part of the dial..to get full speed. indikation
 .a spedo need to be harmonic..100 miles/160 kmt abaut a 2 am../2 o clock
i hate all this v-w.... vords
Offline aminemed
« Reply #9 on: May 30, 2017, 11:54:57 AM »
how big will be my speed difference between my speedo and reality ?? 5% ?
Offline strynboen
« Reply #10 on: May 31, 2017, 09:24:41 AM »
at some speeds it almost perfekt..and up to 10% vrong at the vorst..mine is metric and indikates 170 at 160 kmt..i vas feeling so happy..until i faund aut...so better dont thek
Offline aminemed
« Reply #11 on: May 31, 2017, 12:15:01 PM »
to be honest I never go further than 60mph, is it still the same speed displayed ?
