Since this is now out there, I should back track it while it will still make sense to any of those reading.
Here's how I got the engine! It was actually a solid deal (Note: potentially my first solid deal with anything relating to this bike???
![Wink ;)](http://forums.sohc4.net/Smileys/default/wink.gif)
) And the guy who sold it to me gave me a nice back story. The garage was filled with rock and roll memorabilia, a 74 Trans Am, a 750 motor, and a bunch of photos of his dads old hot rods and projects.
I forget roughly how many years this motor has been sitting, but it's been quite a while.
![](https://farm5.staticflickr.com/4666/39040437425_84e2a20234_c.jpg)
This thing fit perfectly in the trunk of my Fiesta ST!
![](https://farm5.staticflickr.com/4706/39938828011_3a5123989f_c.jpg)
![](https://farm5.staticflickr.com/4613/39040445135_cea89905c2_c.jpg)
![](https://farm5.staticflickr.com/4695/39938830751_f76b8207de_c.jpg)
![](https://farm5.staticflickr.com/4675/39317369154_352e83a43d_c.jpg)
![](https://farm5.staticflickr.com/4696/39995662622_c9571f3c96_c.jpg)
![](https://farm5.staticflickr.com/4748/40027081041_0c7e417be3_c.jpg)
First off, let's do a little comparison here. The oil filter housing on the CB550:
![](https://farm5.staticflickr.com/4761/39228323374_9a902dc307_c.jpg)
Oil filter housing on the 500 (Original motor) ((After already cleaning out the oil))
![](https://farm5.staticflickr.com/4328/35909200766_3ffcbe1ca8_c.jpg)
Oil pan on the 550: Comment referencing to the pieces of gasket found in pan.
![](https://farm5.staticflickr.com/4672/40077392872_4647ac6721_c.jpg)
Oil pan on the 500:
![](https://farm5.staticflickr.com/4430/36976459180_eb888cbbb2_c.jpg)
![](https://farm5.staticflickr.com/4416/37202310362_477f64fa37_c.jpg)
![](https://farm5.staticflickr.com/4426/36561544553_1e160f8185_c.jpg)
Valve cover off! Was a bit hesitant around this point because 3 of the breather cover bolts seized and stripped. This was kinda scarring me as I was using my typically successful technique. Luckily, it's been smooth sailing from that point on and I haven't come close to stripping anything since, except....
![](https://farm5.staticflickr.com/4715/25067187867_b0693f8e9a_c.jpg)
![](https://farm5.staticflickr.com/4714/39040449555_61b52a9212_c.jpg)
I knew once I saw this that the PO definitely romped on this thing...
![](https://farm5.staticflickr.com/4742/39040451275_4a42aa8bcb_c.jpg)
This time I got around to checking ring orientation. Cylinder 1 was the only one with a more ideal ring orientation. The rest of them were pretty off or just gaps right on top of each other.
![](https://farm5.staticflickr.com/4746/39906608032_c9a8790b50_c.jpg)
A little leaky! Later on I found a piece of gasket wedged in there; potentially got in there when it was sitting and was wedged into place? Was a bit odd but either way valve lapping is pretty easy for me at this point so I would be doing this regardless.
![](https://farm5.staticflickr.com/4755/39938826191_09c88de761_c.jpg)
![](https://farm5.staticflickr.com/4610/26066546678_d42d730a72_c.jpg)
You can see a "recent" rebuild was done, the valves were pretty darn clean or at least the buildup was quite little. Definitely was running rich though for the time after the rebuild. I want to note how flawless the valve stems were, too, as comparing to the ones on the first
500 head, they had horizontal fine scratches from spinning and I guess overall wear. The valves, valve springs, and the retainers on the
550 head seem really new and in great condition. Sometimes you don't realize how bad and out of shape things were until you see new right in front of your own eyes.
![](https://farm5.staticflickr.com/4621/39906608352_dfe522869f_c.jpg)
This washer though... Don't know how many times this was reused...
![](https://farm5.staticflickr.com/4756/39040440085_68030f4814_c.jpg)
While I was disassembling this, I went ahead and purchased a cheap bore gauge and a honing tool. I took some readings on my CB500 jugs, and decided to practice honing on it. Luckily, the readings were consistent and the cylinders were just barely out of round. I have yet to take readings on the honed version, but hopefully this weekend I can get back to tackling that.
![](https://farm5.staticflickr.com/4671/39938827581_28ca71dcfc_c.jpg)
Here's a pic of the current result, you can see there's still staining at TDC, so I still have a ways to go!
![](https://farm5.staticflickr.com/4745/26154627518_0a13fe300d_c.jpg)
Back to the CB550***Cylinder jug off, finally seeing some cross hatching! But there is also some scoring marks, a TDC ring, and a couple of areas where the oil ring pattern can be seen on the cylinder wall. Still, let's compare it to the
CB500 so we can see the difference:
![](https://farm5.staticflickr.com/4442/36551677416_7c41322a4f_c.jpg)
![](https://farm5.staticflickr.com/4702/39906610172_09cb46296a_c.jpg)
I did something I knew would be quite risky, but I also knew many people have used this method with success, so I bent the studs and broke them free this way. All went well, except the short stud in the corner of cylinder 1 completely split itself in half and broke apart, except for what's left of it in the case. Luckily, I know I will be able to get it out, I'm soaking it in penetrating oil and I'm going to put it through a dozen heat cycles to help free it. That is something I will jump back to with patience.
![](https://farm5.staticflickr.com/4624/39129058095_665efb23cd_c.jpg)
You can see the bit that's left here:
![](https://farm5.staticflickr.com/4651/25156566227_1007c6594f_c.jpg)
My trick for splitting the cases? Excessive amounts of razor blades. Dave saw a couple photos of this engine beforehand and immediately noticed how much sealant I was dealing with. If you take a look back at the head studs you can see red streaks on them from some other sealant used on the head. Sealant everywhere.
![](https://farm5.staticflickr.com/4701/28248321429_f64ddecc6f_c.jpg)
![](https://farm5.staticflickr.com/4602/39129062725_20df1f572b_c.jpg)
Looks solid...
My started break down space. The teddy bears add 5hp.
![](https://farm5.staticflickr.com/4759/40027068481_4ef09e6dd3_c.jpg)
This has accumulated many more parts now.
![](https://farm5.staticflickr.com/4703/39398375634_5eba5b60ba_c.jpg)
![](https://farm5.staticflickr.com/4649/39211328795_9e26e15262_c.jpg)
![](https://farm5.staticflickr.com/4674/28329455729_14b3b7444d_c.jpg)
![](https://farm5.staticflickr.com/4703/28329455299_ee647f39d8_c.jpg)
I would say next step is removing the rest of the bits from the bottom case, including the kick starter shaft, and then from there go into the soda blasting process. Need to save up money for the primary chain.
