Author Topic: Marissa's 1972 CB500  (Read 92797 times)
Offline knosalaa
Re: Marissa's 1972 CB500
« Reply #575 on: December 17, 2019, 09:13:02 PM »
Just a quick question, and btw after 10 pages google showed no answer, can you charge lead acid standard motorcycle battery with agm charger? I know you can’t use standard charger on agm batteries but my question is the other way around. I have a bmw agm charger/maintainer we use to charge when in vacations.
« Reply #576 on: December 17, 2019, 09:53:52 PM »
This is a common symptom when a couple of things are present.
One is: too-soft springs in the spark advancer (this will make it REAL sensitive to anything else that is wrong).
Another is: the tiny O-rings on the mainjets are too old and have turned to plastic now (thanks in part to ethanol), so they leak fuel past them, unmetered fuel.
One thing that may get you running long enough to figure out if the carbs are the culprit or the spark advancer is: retard the spark timing to almost "T" on both sets of points, by turning the whole points plate CCW a little. Then when it starts it will be retarded in timing, making it less sensitive to the spark advancer portion of this issue. If it still wants to jump up and idle at 3500 RPM (like it sounds) then the mainjet O-rings are likely at fault. Given your dark sparkplugs (or were those from the other carbs?), this seems likely.
The biggest issue we are seeing right now in rebuild kits for these carbs is: too-big O-rings in the non-Honda kits. This prevents the jets and the float valves from being assembled properly, even to the point of breaking parts. They are supposed to be 1.2mm in cross-section, but the kits supply 1.5 or 1.6mm instead, causing the trouble. This is the #1 reason why it seems so hard to rebuild the CB500/550/400fcarbs these days!
The carb 'rebuild' consists of (besides cleaning) replacing the O-rings on the mainjets, float bowl drain screws, and the fuel feed tubes, and sometimes the float bowl O-ring that seals it all up. It's pretty simple, especially for someone with fingers as nimble as yours! It's just hard to get the right O-rings. I have tried before (and may try again) to have a local seal shop import a bag full of these tiny ones: if I can get them, I'll let everyone here know about it.
Like “Donkey” from Shrek says, “Oh, pick me!  Pick me!” With regard to having my hand up on wanting a set or two of the O-rings for the 550. If stored in cooler conditions and not where UV light are the Orings are showing bad wear...then maybe the Silverstone section can enlighten me on the
« Reply #577 on: March 24, 2020, 08:05:45 PM »
Marissa, how are you?  How is life treating you and your family and friends?  Any work on the bike since last report?
I hope you and family and friends are staying healthy.
Offline Marissa
« Reply #578 on: June 21, 2020, 06:02:07 PM »
Hi RAF!
My bike is now finally ridable. You may have seen DaveBarbier's post with setting float height on CB500 carbs with a whiskey glass, that was actually for my bike. Dave dialed in float height, found my valve lash for virtually all valves got loose, and got some seat time in and later adjusted needle settings for me! Wouldn't be here without him. Super happy.
The bike is still very much a project. Currently I still need to remake my sub harness, extend the harness for the "idiot lights", add a relay/transistor for the LED turn signals, adjust my rear brake pedal, etc. But right now I'm having some issues with the rear end, and the threaded bearing retainer. Also w/my 2nd Shorai battery  >:(
Attaching some pictures for now, my spacebar key is broken and I have a Mac so I have to bring it to Apple to fix. Until then won't have a lot of story to tell!
1984 Nissan 300zx - sold
2016 Ford Fiesta ST - daily
1972 Honda CB500 - infinite work in progress
Instagram- marissasimos
« Reply #579 on: June 21, 2020, 10:02:11 PM »
What's up with your threaded bearing retainer? Drill out the stakes areas before starting to get it removed I hope.  DSS, David Silers Spares carries a bearing retainer removal tool but the one I bought from them I had to return as it could only fit three of the four circular staked holes instead of four as it was supposed to.  I made them aware of the problem and they accepted the return no problem and took the product down for a while. Presumably to get their supplier to fix the problem. It worked very well to remove the bearing retainer even with only three of the four engaged.  The bolt circle/radius the pins for remove the bearing retainer was fitted to was a mm or so off, enough to cause the problem. They checked it with an aftermarket retainer, same problem, and a original equipment bearing retainer as well. Just to rule out the aftermarket parts being the issue.
Glad Dave lent you a hand and you have been enjoying the bike.
Hope you can continue to do so this summer and nothing major takes it off the road on you. Two wheel therapy is far better than a shrink's fees.
Offline Scott S
« Reply #580 on: June 22, 2020, 03:37:47 AM »
 And if you're talking about the rear wheel retainer, it's reverse thread. Make sure you're going in the right direction! It's a very fine thread too, so be careful when you go to thread it back in.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #581 on: June 22, 2020, 02:27:43 PM »
Great to see you are still at it!
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline Marks78
« Reply #582 on: June 24, 2020, 01:39:15 PM »
Great news! Glad to hear you didn't give up on it. Now that it's rideable at least you can have fun in between down times.
Current Stable:
1978 CB750K
1982 XT200J
1982 XJ1100 Maxim
1985 V30 Magna
1998 VT1100 Spirit
2006 GoldWing
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #583 on: April 11, 2021, 05:58:16 PM »
Marissa
Is there anything new to report on your project?
1973 CB 750 K3
Offline newday777
« Reply #584 on: July 24, 2023, 04:22:34 AM »
I see it's been 3 years since any update. Are you still with us???
Stu
My current rides
Prior bikes....
« Reply #585 on: July 24, 2023, 06:38:34 AM »
She hasnt been on here in over two years
Offline newday777
« Reply #586 on: July 24, 2023, 11:24:14 AM »
I saw that but hopefully she gets notifications still and will reply back. Hopefully she is OK.
Stu
My current rides
Prior bikes....
Offline jgger
« Reply #587 on: July 24, 2023, 12:07:57 PM »
She was a determined gal, I enjoyed reading her posts. I think she had half the forum cheering her on.
I too would like to see an update.
« Reply #588 on: August 19, 2023, 02:38:26 AM »
Given her age I think she has more important things to worry about.
« Reply #589 on: August 21, 2023, 01:56:18 PM »
Interesting article about her....
http://crescentmagazine.org/proving-herself
Offline jgger
« Reply #590 on: August 21, 2023, 02:42:40 PM »
Interesting. Good on her in her endeavors, but she could check in at least to say hi.
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #591 on: August 22, 2023, 06:10:46 PM »
Great to see her making her way! Hopefully one day she will find a minute to return to the forum.
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
Future project 77 Cb750 Amen Savior
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #592 on: August 24, 2023, 05:38:04 PM »
Cool article. Looks like her plate is full, it would be great if she eventually completed it but life happens!
1973 CB 750 K3
