Author Topic: Rear light on 76 550  (Read 971 times)
Offline FIREBLADE74
« on: June 02, 2017, 06:01:58 PM »
Plain and simple!
Somebody please tell which wire I splice in the tail and headlight bucket to get running rear light, I don't wanna buy a new ignition.
Please this color blind sh!t is driving me nuts!!!!
Pics would be great!!
Thx!
06 CBR1000RR, 76 CB550
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
Re: Rear light on 76 550
« Reply #1 on: June 02, 2017, 06:51:19 PM »
Hate to tell ya man, but if your key switch is toast, there's no sense in rewiring things around it.
They are serviceable, have ya done that yet?
Offline Smudgemo
  • Maker of Stuff
« Reply #2 on: June 02, 2017, 09:04:25 PM »
You keep having this problem and I really don't think you need to start cutting wires to fix it.  Did you pull the ignition and check if it's the problem?  I showed you how to check it in another thread and you don't need to see any colors.  It's really not hard to get the ignition switch out of there, and you don't need to even pull the headlight bucket to access it.  I can take some photos to illustrate if it helps.  550F, right?
If you need to replace the cap to keep the switch components in place, you can order one of my 3D printed copies (if it fits your model) and get it working properly.  It's not a perfect swap yet, but the plastic files easily and mine works perfectly.  My switch wasn't working properly due to either corrosion and/or the broken cap not keeping tension on the switch contacts.
-Ryan
Thread - How to fix your starter button (for real): http://forums.sohc4.net/index.php/topic,163170.0.html
Offline Smudgemo
  • Maker of Stuff
« Reply #3 on: June 02, 2017, 09:06:56 PM »
-Ryan
Offline FIREBLADE74
« Reply #4 on: June 03, 2017, 10:01:35 AM »
It is my ignition! I don't want to have 2 keys if I got a new ignition.
1 key for ignition and another for tank and seat.
  • Holy Cow! I'm a
« Reply #5 on: June 03, 2017, 10:09:48 AM »
THEN FIX IT!  Do what smudgemo says 😁
Offline FIREBLADE74
« Reply #6 on: June 03, 2017, 10:21:50 AM »
No doubt
« Reply #7 on: June 03, 2017, 10:38:16 AM »
Imo, two keys is better than no tail light.  Even if only interim.  Then you can fix your broken key switch at your leisure.
Then you have a working spare, or a part to barter.
Offline Smudgemo
  • Maker of Stuff
« Reply #8 on: June 03, 2017, 11:00:53 AM »
You know, this is a good idea.  It's not too hard to pull the ignition and the "improved" replacement is only $20.  You'll be up and running in an hour
Or you could get the ignition/seat lock combo for $33 and have only one key.  The fuel lock isn't really a lock - it will open with the replacement key.  I just tried with my aftermarket ignition replacement key.  http://4into1.com/new-improved-ignition-switch-fork-lock-assembly-seat-lock-set-honda-cb400f-550-650-750/
It's really a ton easier and is an actual fix as opposed to cutting wires and booger-rigging things.
« Last Edit: June 03, 2017, 11:06:23 AM by Smudgemo »
-Ryan
Offline FIREBLADE74
« Reply #9 on: June 03, 2017, 11:48:32 AM »
Thx guys, I only saw the ignition replacement, never saw the set. Will be ordering asap.
