Author Topic: smoke out of breather  (Read 851 times)
Offline yellowjacket
« on: June 05, 2017, 10:13:26 AM »
Been riding the 550 and it runs well no problems.  Noticed it has been smoking a little out the breather.  I checked to see if the top end is getting oil by looking into the tappet caps while the engine is running.  There is oil slothing around in there.  I also rebuilt the oil pump awhile back.  Is this somewhat normal or do I have a concern here?
Thanks
Re: smoke out of breather
« Reply #1 on: June 05, 2017, 10:15:20 AM »
Normal, but ensure all your periodic maintenance items are take care of.
Offline markreimer
« Reply #2 on: June 05, 2017, 10:22:51 AM »
My 750 does that too. Before and after a top end rebuild. Sometimes it's as simple as condensation burning off, especially if you park it somewhere cold overnight. Usually mine is gone after a long ride, but not always. Like the last guy said, make sure all your maintenance items are up to date - can chain tension, valve clearance, points (if you have them), timing, oil change etc - if you've still got a bit of smoke I wouldn't worry. Is it white? Blue smoke usually indicates burning oil. Mine is white, water vapour
« Reply #3 on: June 05, 2017, 09:20:34 PM »
It is white smoke and everything on the bike has been checked recently.  Thanks
Offline Deltarider
« Reply #4 on: June 05, 2017, 11:39:09 PM »
It is white smoke
Your bike signals a habemus papam latin for we have a (new) pope. Good your bike doesn't vent all that moist (or part of) into the aircleaner filter element.
« Last Edit: June 05, 2017, 11:41:23 PM by Deltarider »
CB500K2-ED Excel black
