Author Topic: front springs issue after triple tree clamp swap  (Read 1387 times)
Offline aminemed
« on: June 06, 2017, 05:33:36 PM »
Hi guys
I think I made a big mistake tonight. I'm in the process of swapping my triple tree clamp, I opened the caps to remove the old triple tree clamp and suddenly, the springs literally jumped out from the forks (bike even fell). Now that I have the new triple tree, it's impossible for me to replace these springs and put the caps back. I hope I didn t do something too bad. Is there an easy fix that does not require rebuilding the forks all over again, attached some pictures
Offline innovativems
    • Innovative MotoSports
Re: front springs issue after triple tree clamp swap
« Reply #1 on: June 06, 2017, 05:42:29 PM »
Put a jack under the front bottom of the motor and slowly jack it up to take tension off the front end.  Out it on center stand when you do it and be careful.  Once tension is off, you can compress the fork springs to out the caps back on the fork tubes
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
Offline aminemed
« Reply #2 on: June 06, 2017, 05:47:43 PM »
unfortunately my center stand is gone (I know it's a long and complicated debate)..know that I need it I don't have anymore..
Offline tlbranth
« Reply #3 on: June 06, 2017, 06:01:48 PM »
Like inno said you need to lift the font end 'til the forks are fully extended. Do you have a garage beam or rafter you could tie on to? Put rope or strap around the handlebars and winch it up. It's going to wobble around a bit without a stand. My wife's VT750 has no center stand and I built a wooden thingy to perform the same function. It slides under the frame and with a wood handle, I rotate it front to back and it lifts onto the wood block. You might want to make one. It'd make lots of maintenance chores easier.
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline drumstyx
« Reply #4 on: June 06, 2017, 06:15:36 PM »
Yeah this has nothing to do with your triple tree...lift the bike or remove the forks (which necessiates lifting anyway) and replace the caps.
« Reply #5 on: June 06, 2017, 06:39:43 PM »
Blocks and shims under the frame both sides..
And now we all know, you didnt get a manual .........yet....
Offline aminemed
« Reply #6 on: June 07, 2017, 12:27:12 PM »
Thania guys was able to fix this issue with a jack. As soon as I lifted the front of the bike, all got back to normal
« Reply #7 on: June 07, 2017, 12:34:38 PM »
work on one fork at a time, and this wont happen  ;)
Offline Steve_K
« Reply #8 on: June 09, 2017, 04:58:23 AM »
With out a center stand , I have used a rear stand and an engine hoist and some tie downs around the frame or triple clamps to lift.
Steve
Steve_K
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #9 on: June 09, 2017, 12:21:16 PM »
Jackstands mate  ;D
Offline aminemed
« Reply #10 on: June 10, 2017, 05:32:59 PM »
now that the old triple clamp is removed with old gauges and indicators (neutral, beam, oil, etc..), I of course disconnected their wiring from the bucket to be able to remove all the items, I tried to start the bike today and my main fuse blown..is there any link with the items that I removed ? thanks
Offline Jimray23
    • none
« Reply #11 on: June 10, 2017, 05:58:46 PM »
Maybe if one of the plugs are bare and against the headlight bucket
Jim
1979 kz1000b ltd
    stage 3 cams
    pod air filters
    4-1 open exhaust(no muffler)
    full rewire
    dyna-s ignition
    dyna 3 ohm coils
  • Holy Cow! I'm a
« Reply #12 on: June 11, 2017, 04:47:15 PM »
Yep, all those indicators run on the main fuse circuit.  Make sure you're insulated against grounding out as Jim mentioned.
