Author Topic: Point set for 1-4 are sparking 78 750F  (Read 621 times)
Offline SS350Sport
« on: June 07, 2017, 05:46:54 PM »
I just purchased a low mileage (5K) 78 Super Sport motor and I am attempting a first start. Everything checks out good except for the points for the 1-4 coil are sparking and the 1-4 plugs are not firing. I have a 77K that likes to eat condensers so I figured this was an easy fix. Not true. I swapped the condenser from the 2-3 side and the 1-4 points still throw spark. I changed the 1-4 point set and it still sparks. I can swap the yellow/blue wire terminals near the rear brake switch and I can get the 1-4 plugs to fire. Any ideas?
74 CB 750K
76 CB 750F
77 CB 750K
78 CB 750K
79 CBX
Offline Glenn Stauffer
  • Administrator
    • The SOHC/4 Owners Group
Re: Point set for 1-4 are sparking 78 750F
« Reply #1 on: June 16, 2017, 04:15:45 AM »
bumping this one up - apologies for the delayed posting; it was hung-up in the moderation queue
Offline lrutt
« Reply #2 on: June 16, 2017, 10:19:41 AM »
Sounds like questionable coil to me.
« Reply #3 on: June 16, 2017, 10:58:16 AM »
Measure the resistance of the coil primary and compare to the coil that is firing.
Remove/unscrew the plug caps from the HT wires and measure the resistance of the coil secondary.  Compare to the 2-3 Coil.
report results.
Offline Dracon
  • Wannabe Old Timer...
« Reply #4 on: June 16, 2017, 11:11:50 AM »
If swapping the blue and yellow wires gets spark to 1 and 4 then the wire from the points to the connector has been severed or corroded somehow.  Try swapping those wires from the other bike and I bet it works.
