Author Topic: flywheel/Alt rotor puuller  (Read 1977 times)
huey
« on: December 18, 2006, 05:23:09 AM »
I have been looking thru the D. Kirk book for the above item but they dont list one specifically for the 550K models. The ones they have range from 16mm to like 24 mm. Can anyone tell me the correct size. Thanks in advance for any help.
Re: flywheel/Alt rotor puuller
« Reply #1 on: December 18, 2006, 07:04:03 AM »
Same as 500 four
Offline crazypj
  • I'm brill, me
« Reply #2 on: December 18, 2006, 11:12:33 AM »
The 'cross' or 'star' 4 way puller has all the sizes you need for multiple bikes, including Honda ;D
use a dead blow hammer on it so you don't damage threads.
PJ
migman750
« Reply #3 on: December 19, 2006, 04:52:01 PM »
Beleive it or not, the back axel has the same size thread as the rotor.  when i changed mine, i made a slide hammer out of the axel with a 5 pund weight from the weight bench, it worked great.
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #4 on: December 19, 2006, 05:07:22 PM »
i've also always used a rear axle. i have a 350T axle i use for my 550 (it has a bolt-head instead of the round type with a hole through it. no slide hammer necessary. just run it in, and it forces the alternator off of the tapered crank-end. helps to have an impact-wrench.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Offline scunny
  • don't call me expert
« Reply #5 on: December 19, 2006, 10:36:07 PM »
same as paulages and migman, rear axle wound in, a tap with a hammer on the end of the axle bolt and the rotor dropped free
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
huey
« Reply #6 on: December 20, 2006, 07:30:33 AM »
Thanks guys for all the tips on the puller. What a great idea on the axle.
