You will have a conflict between your new seat hoop/pan and rear tire
This "modification" is very popular, and so too is the issue. The factory hoop had that "offset" bridge to allow suspension travel and the tire to move vertically under compression and not touch the inner fender. You'd best stop now and confirm that either suspension changes you're making (longer shocks) or a smaller tire (probably need a 16") or both will accommodate the new hoop.
