Author Topic: Bypassing starter relay safe?  (Read 10811 times)
Offline crumpet8
« on: June 11, 2017, 11:20:06 am »
Hi,
So I'm hoping to attach some heavy gauge wire across the relay bolts to bypass it and jump current straight to the starter. Yes, I know I should just by a relay but bear with me :)
All info is greatly appreciated!
How safe is this? What gauge wire? type of switch? Should I wire in some sort of fuse?
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
Re: Bypassing starter relay safe?
« Reply #1 on: June 11, 2017, 11:48:19 am »
The reason the starter solenoid (relay) exists is so the damn thing shuts off!
If you're desperate to start your bike electronically - use a screwdriver with a rubber handle.
Or kick start it like a champ  ;D
75 CB550F Bloo
03 DS650/720 Bombardier
76/78 XS750 Oscar the Grouch
07 FJR1300; Lydia
05 YFZ450/470 Stroker (sold)
73 Norton Commando 850 Cafe
99 Roadstar Silverado (rebuild)
Certified Harley Davidson Tech
Offline NobleHops
  • Don ya be callin' me no
  • Misfit - Tucson, Arizona
« Reply #2 on: June 11, 2017, 12:15:58 pm »
Hi,
Not a great idea. That starter and battery cable is a big wire pulling a lot of current through it. What makes you wish to do this? You are better off momentarily bypassing it with an insulated screwdriver as suggested if you just want to test or otherwise run the starter.
Once upon a time, long ago, an energetic but less informed....PERSON I KNOW *cough* wanted to turn over his starter and the engine it was attached to while it was out of the motorcycle. I ^h^h^h^h^h THIS GUY thought to himself, "Hey, that Romex over there looks pretty beefy, has to be good for 40 amps or so". and wired it up to his starter, grounding it to his engine. When I ^h^h^h HE put spark to this setup, the starter did dutifully spin, and all seemed right in the world for about 10 seconds, until the insulation of the romex melted to the consistency of maple syrup, and came this >< close to shorting together.
I advise caution with this :-).
P.S. Just googled this, and one fellow put his DC clamp meter on his Aprilia and measured it:
Peak draw: 61 Amps
Continuous cranking draw: 33 amps
« Last Edit: June 11, 2017, 12:22:09 pm by NobleHops »
I have a motorcycle problem.
Offline koendd
« Reply #3 on: June 11, 2017, 01:24:05 pm »
just use a screwdriver as stated before (insulated  :o)
no idea why you would want a permanent bypass since the starter motor will keep spinning then;..
1972 cb750K2 brat
1976 cb360
1984 GPZ900R
Offline crumpet8
« Reply #4 on: June 11, 2017, 01:53:06 pm »
1980 cb650 = no kick start.
I'd install a toggle switch to turn it off right after the bike starts. Figure there'd be less sparks and burnt spots on my screwdriver and bolts...?
Reason for the quick solution is I'm thinking of selling it before moving next month, but would also be nice to ride around without having to take off side cover etc. to start it up in the morning. Easy push start when warm :)
« Reply #5 on: June 11, 2017, 01:58:24 pm »
I agree with the others
CB750 starter motor is specified 600W. 600W/12V=50A  That's why the wires are thick.
I should test a thick screwdriver for fault tracing only, to verify that the motor is functional if not starting by the button. Connection in max 2-3 sec
Edit: I bought a cheap starter relay for my next project, CB750 K2. It fits my holder after I added a turn or 2 with vulc rubber tape.
http://www.ebay.com/itm/200946091392?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
« Last Edit: June 11, 2017, 02:02:10 pm by PeWe »
CB750 K6-76 1005cc JMR Billet block.
Offline koendd
« Reply #6 on: June 11, 2017, 02:01:34 pm »
just rewire it then?
there's 2 wires coming from the starter relay (apart from the big ones to battery and starter off course).
The other 2 thin gauge wires: yellow/red: wire that through a pushbutton switch with a switched +, the other one is ground.
problem solved...
1972 cb750K2 brat
1976 cb360
1984 GPZ900R
Offline przjohn
« Reply #7 on: June 11, 2017, 02:06:37 pm »
Hi,
Peak draw: 61 Amps
It is nice to know others besides myself have had their, "Moments"  shall we call them. :)
  • Holy Cow! I'm a
« Reply #8 on: June 11, 2017, 03:04:55 pm »
Reason for the quick solution is I'm thinking of selling it before moving next month.
You could wire a momentary push button to the stock "start button" wires and fix the new button under the tank.
$10 and 20 minutes.
Do it nicely and the future owner won't despise you for it  ;D
75 CB550F Bloo
07 FJR1300; Lydia
Offline NobleHops
« Reply #9 on: June 11, 2017, 03:40:36 pm »
$10 and 20 minutes.
This is the right idea. The two smaller wires connected to the solenoid trigger the solenoid. Switch them as suggested WITH A MOMENTARY SWITCH (not a regular toggle) and you should be back in business. Or just fix the friggin' thing. A used switch is a whopping $25...
http://www.ebay.com/sch/i.html?_from=R40&_trksid=p2380057.m570.l1313.TR0.TRC0.H0.X35130-463-505.TRS1&_nkw=35130-463-505&_sacat=0
...and you can still buy a new one for $90:
http://www.partzilla.com/parts/detail/honda/HP-35130-463-505.html
Offline NobleHops
« Reply #10 on: June 11, 2017, 03:43:09 pm »
Quote from: przjohn
Let's team up and write the book. I've got several chapters' worth of 'moments' if I can just remember them all :-)
Where ya been John? Haven't seen you about. Are you building anything at the moment?
N.
Offline NobleHops
« Reply #11 on: June 11, 2017, 03:45:32 pm »
P.S. If the solenoid is the problem and not the switch, I bet I have one that you can have for the price of postage. Fix it right.
Offline crumpet8
« Reply #12 on: June 11, 2017, 04:27:08 pm »
Thanks everyone, but sorry I guess I didn't explain this clearly... the relay is the issue, a switch for the low voltage lines (or whatever they're called?) I can make With leftovers in my tool bag, but have little idea about relays :)
 The relay isn't working, hence the reason I'm bypassing it (currently with a screw driver).
  • Holy Cow! I'm a
« Reply #13 on: June 11, 2017, 04:32:01 pm »
Then take up noblehops's offer of a working solenoid!
75 CB550F Bloo
07 FJR1300; Lydia
Offline NobleHops
« Reply #14 on: June 11, 2017, 04:40:03 pm »
I will look for one tomorrow. Drop me an email please to nils@restocycle.com
P.S. Those can actually be opened up, the contacts within cleaned and the solenoid fixed.
N.
Offline crumpet8
« Reply #15 on: June 11, 2017, 10:58:34 pm »
Hei Nils!
Great build thread by the way :) I'll shoot you an email later today. Might have to wait a week to get paid/after my exams.
Offline crumpet8
« Reply #16 on: June 11, 2017, 10:59:30 pm »
May take it apart first to see if I can clean it as you recommended too.
Offline NobleHops
« Reply #17 on: June 12, 2017, 06:41:36 am »
Good place to start - and if not, let me know.
Best,
N.
Offline przjohn
« Reply #18 on: June 12, 2017, 05:16:16 pm »
Quote from: przjohn
N.
Have a 550 to rebuild next Winter. Took this past Winter off and worked on other odd jobs.
Offline DaveBarbier
« Reply #19 on: June 12, 2017, 07:28:51 pm »
Yes, the posts on the inside can be cleaned. But the copper bar can be flipped upside down to reveal fresh copper. Super simple. Then you won't be one of those PO's that we all despise, haha.
Offline crumpet8
« Reply #20 on: June 20, 2017, 02:37:54 am »
Hey Everyone, so I took out the relay, gave it a good clean, checked continuity to it and all is good again. Thanks for the help :) here's a pic of my bike by the way.
Offline Kevin D
  • SE Michigan
« Reply #21 on: June 20, 2017, 06:34:12 am »
Nice clean bike...... and how did the exams go?
71 CB750 K1
100,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Offline DaveBarbier
« Reply #22 on: June 20, 2017, 06:56:07 am »
Nice 650, glad you've got it fixed.
Offline NobleHops
« Reply #23 on: June 20, 2017, 06:59:13 am »
Excellent, well done! Great bike!
Offline crumpet8
« Reply #24 on: June 20, 2017, 01:34:09 pm »
Haha spent today fixing the relay etc. instead of reading so am going to really get some reading done tomorrow :) thanks for asking! Fingers crossed it goes ok... think it'll be fine.
