Author Topic: Blowing fuses  (Read 661 times)
Offline evinrude7
  • not a kung-fu
  • something to hüsker
Blowing fuses
« on: June 11, 2017, 01:50:52 PM »
If my regulator is not installed on the bike and I turn the key to on could that blow the main fuse? Or did I mess something up when I ran my wires thru the new bars? They went thru in a matter of minutes. It was almost too easy.
Sent from my LG-H871 using Tapatalk
cb750 k6 - ugly
Offline evinrude7
  • not a kung-fu
Re: Blowing fuses
« Reply #1 on: June 11, 2017, 02:42:37 PM »
hey evinrude7 one of your bulb sockets was rubbing on the metal part of the dash.
cb750 k6 - ugly
Offline evinrude7
  • not a kung-fu
Re: Blowing fuses
« Reply #2 on: June 11, 2017, 02:51:22 PM »
BTW, the answer to the Reg/Rec question is "No" in principle, unless you short circuit running voltage from it to ground  :)
thank you sir.  i found it after i disconnected the right side controls and it still blew.  then got to the left side controls and tugged on the wires.  i looked over to the dash just as the fuse blew and noticed a socket rubbing.
cb750 k6 - ugly
