Author Topic: Timing and Timing lights  (Read 2435 times)
Offline SKTP
« on: June 12, 2017, 12:05:52 pm »
So I am now at the "get this thing running perfectly stage".
So from what I figure, that's timing and then carbs. My bike is popping a bunch on deceleration but pulls better than ever with the gas.
I took my first crack at STATIC TIMING yesterday and really from what I could tell end up just moving the timing plate a few degrees and testing it anyways...the actual light does not give a precise spot, more like a range to try...unless I'm doing it very wrong.
So that leads me to believe I will get better results with Dynamic timing and a Timing light. Correct?
Anything to watch out for when purchasing a timing light?
Thank for any feedback
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Online grcamna2
Re: Timing and Timing lights
« Reply #1 on: June 12, 2017, 12:18:17 pm »
A self powered inductive timing light will be best,if you can find 'self powered'
Offline Jimray23
    • none
« Reply #2 on: June 12, 2017, 12:30:54 pm »
Popping on deceleration is typically carbs running a little lean.
Jim
1979 kz1000b ltd
    stage 3 cams
    pod air filters
    4-1 open exhaust(no muffler)
    full rewire
    dyna-s ignition
    dyna 3 ohm coils
Offline DaveBarbier
« Reply #3 on: June 12, 2017, 01:46:06 pm »
I have a cheapo timing strobe and it works fine for me. I've never used anything other than that though. But yes, it's best to check timing with a strobe because you can check your timing at advance. Since these bikes are ridden 99% of the time over 3k rpm, your advance setting is more important than idle setting.
For my tune ups, I do static first so I'm close and then Do a dynamic with a strobe and tweak if needed.
Offline DaveBarbier
« Reply #4 on: June 12, 2017, 01:46:46 pm »
Jim
1979 kz1000b ltd
    stage 3 cams
    pod air filters
    full rewire
    dyna-s ignition
    dyna 3 ohm coils
Over advanced can cause a lean running condition
« Reply #5 on: June 12, 2017, 02:02:25 pm »
Heavy deceleration can pop when carbs are closed, engine still revving on higher rpm in need of more fuel.
No problem, that how it will work with correct carbs, ignition.....?
Offline SKTP
« Reply #6 on: June 12, 2017, 02:11:03 pm »
Everything in the engine is bone stock. Carbs Stock. Stock airbox. 4-into-1 pipe (not stock)
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline Bailgang
  • Scott
  • Indiana
« Reply #7 on: June 12, 2017, 02:22:08 pm »
That's how I do it too, I've gotten pretty good with the static timing because I very seldom have to mess with it afterwards but I always back it up with the dynamic timing just to confirm it anyhow.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
Offline tlbranth
« Reply #8 on: June 12, 2017, 05:39:49 pm »
Popping in the exhaust when heavily decelerating is normal for the old bikes. No worries.
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline Keith
« Reply #9 on: June 12, 2017, 06:00:23 pm »
Just my two cents, but you are actually tuning two ignition systems, trying to get them timed exactly the same. I reccomend buying a decent timing light and dwell meter. Very difficult to get it right on without these basic tools.
Offline Jimray23
    • none
« Reply #10 on: June 14, 2017, 05:01:54 am »
Theres a honda mechanic that has free how too videos on his website. I dont agree with his float setting opinion but some of his stuff is really good.if you want to check it out, here is a link.
http://motorcyclemd.com
Jim
1979 kz1000b ltd
    stage 3 cams
    pod air filters
    full rewire
    dyna-s ignition
    dyna 3 ohm coils
Offline SKTP
« Reply #11 on: June 14, 2017, 11:06:51 am »
No video on timing...but thanks for the link
http://motorcyclemd.com/videos/
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline riverfever
« Reply #12 on: June 14, 2017, 08:46:43 pm »
I'm running Dyna ignition and 5ohm coils and currently trying to tune at altitude. I set the ignition static years ago and verified it recently but have never checked to make sure the advancer works properly. Probably should before I continue to chase and tune huh? Plugs are very rich in the mid range with the clips in the third slot. Clips in the second slot showed lean though. I'm going to shop for a timing light I guess. Sorry for the hijack SKTP.
Offline DaveBarbier
« Reply #13 on: June 15, 2017, 04:33:57 am »
Mid range meaning RPM? Only throttle position determines what system is delivering fuel. You'll need to do plug chops at specific throttle opening to figure out what's actually going on. You could still be lean in the pilot while being rich when the needle is in full effect. I believe it's best to start with an idle chop then go to WOT, then work back from there 3/4, 1/2, 1/4, etc.
Offline riverfever
« Reply #14 on: June 15, 2017, 08:38:05 am »
Sorry David I was referring to mid throttle. At 1/4 to 1/2 the plugs are very rich with the clip in the third slot now. I previously had them in the second slot and things were lean.
