Author Topic: Need seat hinge and pin (new) 77 CB750 F  (Read 899 times)
Offline schu3507
« on: June 15, 2017, 05:37:13 PM »
Hey y'all. Put new seat on. Hinge has some play in it and would like to replace. Thought on locations new OEM or repro one?
77 CB750 F super sport
Online HondaMan
Re: Need seat hinge and pin (new) 77 CB750 F
« Reply #1 on: June 16, 2017, 05:38:21 PM »
Is it bent, or sorely worn?
Check with PartsNmore.com: I have seen seat hinges and pins there before. You sort of have to dig thru it manually, as I recall, because the 'search' classification missed it when I tried to find it again later.
Offline schu3507
« Reply #2 on: June 18, 2017, 04:42:55 AM »
Thanks bro! Yeah wore out and has play in seat from that point of contact
Online HondaMan
« Reply #3 on: June 18, 2017, 01:48:49 PM »
I have, on occasion, cut a short length of thin brass tubing to slip over the pin and take up the slack (my old K2 seat got like that). I got the brass tube at the hardware store (thin stuff), slit it to fit the pin (it wasn't metric) and sanded the pin clean and applied lacquer thinner: then I made sure it would slide into the slit tube and super-glued it on. I never moved in 10 years of riding, either! I used a Dremel with a cutting wheel to slit it.
