Author Topic: Time to change chain tensioners - change rings too?  (Read 952 times)
Offline Magpie
« on: June 16, 2017, 11:47:38 AM »
I have  a 1971 750 with about 13,000 miles on it. I think it may be time to change the primary and cam chain tensioners. The motor is running strong and not pushing blue. While I have it apart should I put in new rings as well? I have a line on a set of standard size rings for cheap. I think a light clean up of the bores, lap in the valves and button it up would be the drill here.
Thanks,
Cliff.
Re: Time to change chain tensioners - change rings too?
« Reply #1 on: June 16, 2017, 12:45:07 PM »
The primary tension has been DC'd by Honda.
Offline Magpie
« Reply #2 on: June 16, 2017, 01:30:23 PM »
Still available at David Silvers https://www.davidsilverspares.com/CB750K1-FOUR-1971/part_104736/  I hope. Cliff.
