Author Topic: Couple of lighting questions on my CB400F  (Read 3650 times)
Offline krksquared
    • Nostalgic Kits Central
« on: June 16, 2017, 09:09:35 PM »
First, I'm really enjoying my new (to me) 75 CB400F! My SL350 now has some competition for my attention. Replacing the 20 year old tires with fresh new Avons made a huge difference in handling. And the brakes are terrific! I'm sorting out some small electrical issues. The PO had a cheap LED H4 base headlamp inserted into a gutted original bulb. Low beam was a joke. I just replaced the lamp with a new original one. Will test tonight.
1. I've noticed that when I switched from low to high beam, the front running lights go out. The front turn signals work ok. This doesn't seem logical.
2. The rear side lights only work as turn signals. They do not perform as running lights. This also doesn't seem logical.
I don't know of any other CB400F's in my area so I thought I'd ask here.
@kennectwithme
1975 CB400F
1971 SL350
1979 CBX
2007 Buell XB9R
2003 Harley V-Rod VRSCA
If it ain't broke, I'm riding...
Offline MoMo
  • Ride like you're invisible
Re: Couple of lighting questions on my CB400F
« Reply #1 on: June 16, 2017, 09:12:43 PM »
all normal
Offline Deltarider
« Reply #2 on: June 17, 2017, 01:06:27 AM »
My advice would be to disconnect the running lights and save a now wasted 16 Watts. It was a gadget for the US market and does not add to safety. On the contrary: it makes blinking indicators less noticed. Furthermore you can save by replacing 23W or even 25W bulbs by the 21W or 18W bulbs other markets had. You won't see the difference. Invest in safety and have a good 55/60 Watts halogen for rides at night and if you happen to have an European type reflector you may change the original (and quite useless) 4 Watts Ba9s for a 20 Watts halogen and use that as a DRL. If I had a sealed beam unit, I'd look for a dustbin.
« Last Edit: June 17, 2017, 03:07:27 AM by Deltarider »
CB500K2-ED Excel black
Offline jas67
« Reply #3 on: June 17, 2017, 07:16:00 AM »
....Invest in safety and have a good 55/60 Watts halogen for rides at night and if you happen to have an European type reflector you may change the original (and quite useless) 4 Watts Ba9s for a 20 Watts halogen and use that as a DRL....
Where can one get a European type reflector that will go in the stock CB400F headlight shell without modification (would also apply to CB350F, CB360T, and likely CB350 twin)?
Classic Honda:
1976 CB400F
1975 CB400F (project)
1975 GL1000
1968 CL175 (1 nice one, one project)
1967 CB77
1967 CB160 (2 of 'em, both projects)
1967 CL160 project
Triumph: 2017 Thruxton R
BMW: 2016 R1200RS, 1975 R90S, 1973 R75/5, 1980 R100S
Ducati: 2013  Monster 796, 2013 848 Evo Corse SE track beast, 1974 750GT, 1970 Mk3d 450, 1966 Monza 250
Moto Morini: 1975 (titled 1976) 3 1/2 Strada, w/ Sport clipons.
Moto Guzzi: 2017 V7III Special,  1977 Le Mans, 1974 Eldorado
Offline krksquared
« Reply #4 on: June 17, 2017, 10:18:47 AM »
Yes Delta, some good ideas. My turn signal lamps are LED. I have to replace burnt out lamps in my speedo & tach so I'm going LED there too. Current saved is current earned  :) Just seems odd that the side marker lights go off when on high beam.
@kennectwithme
1975 CB400F
1971 SL350
1979 CBX
2007 Buell XB9R
Offline jas67
« Reply #5 on: June 17, 2017, 10:21:34 AM »
I've got LED's all around on my CB400F except for the headlight.
There I've got the H4 halogen in a hacked stock headlamp hack.
Eventually, I'll put an H4 LED in there.
I don't ride this bike at night, so, I'm more concerned with being seen than how good beem it throughs to see.
Classic Honda:
1976 CB400F
1975 GL1000
1967 CB77
1967 CL160 project
« Reply #6 on: June 17, 2017, 10:57:57 AM »
The side markers/running lights are there to help visibility, as in being seen by folks in other vehicles.  The side markers/running lights do help this visibility and I've read studies that show this to be true.
However, other vehicles should not be blinded by your bright lights in high beam.  This is counter to safety to have blind oncoming drivers.  And there are laws stating that dimming is required practice.  So, when your brights are on the running lights go out to save power, as there should be no one else to see them anyway.
Also, the front running lights are turned off for the side that is blinking, so as to be more prominent, they blink from bright to dark, rather than bright to dim.  This makes them more noticeable to others, which is the point of having turn blinkers.  This is the way the stock turn switch operates if wired properly.
Offline jas67
« Reply #7 on: June 17, 2017, 12:34:32 PM »
FYI, check out this thread for a headlight 6.5" shell that will work on a CB400F:
http://forums.sohc4.net/index.php/topic,165983.0.html
Here is the headlight:
http://4into1.com/build-your-own-6-5-side-mount-halogen-headlight/
Classic Honda:
1976 CB400F
1975 GL1000
1967 CB77
1967 CL160 project
Offline flatlander
« Reply #8 on: June 19, 2017, 01:21:24 AM »
search the interweb (ebay, amazon, etc) for h4 reflectors by hella or bosch. i got a nice new hella for my 550 that fits perfectly. make sure you find one with the right diameter. a new reflector really makes a difference.
Offline Deltarider
« Reply #9 on: June 19, 2017, 02:33:54 AM »
It sure does. My bike came with H4 halogen 55/60 Watts in an appropiate Hella reflector. Hella, Bosch, Cibié, Maréchal, they're all good. Then fit the Philips X-treme Vision Moto and you'll have the best headlight possible for acceptable costs. If you're really worried about the charging system (you shouldn't IMO), you could opt for the Philips H4 Ecovision that draws 20% less, yet performs better than any standard H4. In European style reflectors you can use the ba9s 'city light' socket to create a DRL to your liking. I choose a 20 Watts halogen, but others can maybe create something usefull with a led. I myself couldn't find a Ba9s led fit (around 450 lumens) for the job (or it would have been a ridiculously big tower with I don't know how many leds) but, who knows, maybe there is one now. The US sealed beam is superior in one aspect only: detecting birds nests in trees.
« Last Edit: June 20, 2017, 08:24:49 AM by Deltarider »
