Author Topic: Replace fork seals without removing forks (plus weird oil lock?)  (Read 700 times)
Offline zabzob
I was inspired by this video to replace the fork seals without removing the upper part of the fork from the bike:
So far, it's going well. My forks seem to be different than what is pictured in the books though. I've got a 75, but maybe these forks are from a different year? Also my oil lock piece, sitting on the end of the inner bit, is missing the bottom rim. Is it busted or is this some variant?
1975 CB750K5
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
Re: Replace fork seals without removing forks (plus weird oil lock?)
« Reply #1 on: June 16, 2017, 10:44:08 PM »
Seems about right.
But that wear on the chrome is unusual and seems inappropriate.
Might want to get that leg out of the tree and make sure its straight and true.
Offline jamesw
« Reply #2 on: June 17, 2017, 02:45:54 AM »
Yea those two pieces from your fork internals are not consistent with a 75 750.
The damping rod shouldn't have that taper. It should be more flat. Also the bottom cap that goes over the rod, should have a flare on the bottom.
That damping rod (at least from the bottom) looks like a 78F rod.
72K-F 750 Cafe
75K 750 Cafe
75F 750 Restoration
Offline zabzob
« Reply #3 on: June 17, 2017, 08:40:25 AM »
Looking at the parts fiche, the 78F seems the closest match to the components I have. Thanks jamesw.
Shop manual I found online says 145-155 cc of fork oil at disassembly for 78 forks of K or F type. Sound right?
1975 CB750K5
