Author Topic: '75 CB 400 Four, could use some help please. Carb issue and 2 cylinders cold.  (Read 822 times)
Offline Jay Roller
Hello all, I've got a '75 CB400 Four that I'm working on making it road worthy. The bike has been sitting in my dads garage for close to 25 years, 15,800 miles. It's pretty clean but definitely not perfect. Photos when I reach 5 posts.   :D
I bought a battery, drained the rotten fuel, added new fuel and it pretty much fired right up. That said, I have issues.
First issue noticed is the fuel overflow hose from the #1 cylinder carb is leaking like crazy. I'm guessing the float is stuck?
Also, for the short time I had it running only the #3 and #4 exhaust pipes got hot. So, #1 and #2 are obviously not firing. Maybe a coil? Or do could that also be a carb issue?
Any tips on where to start would be appreciated!
Thank you!
Offline harisuluv
Coil would be 1&4 or 2&3.  Sounds like you have clogged jets.
Offline krusty
I had that 1-2 or 3-4 not firing on my CB750F. Turned out to be old plug caps. This was after cleaning the carbs.
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
