Author Topic: Russ Collins Webers  (Read 5142 times)
Online scottly
Re: Russ Collins Webers
« Reply #25 on: June 22, 2017, 08:36:54 PM »
So what are the whizbang magic features?
In addition to the already mentioned adjustability, the Weber is supposed to do a proper job of mixing fuel and air at a lower pressure differential across the venturi than most carbs, and was considered to be the next best thing to fuel injection, which requires no pressure differential at all. The emulsified fuel from the main circuit is delivered through the "bomb site" in the auxiliary choke, in the center of the airflow where the velocity is high, rather than the needle jet at the bottom of a slide carb, where the velocity is low.
I have accurately measured 51+ MPG over a 700+ mile trip, and have noted mileages as high as 60+ at lower speeds. ;D
« Reply #26 on: June 22, 2017, 08:53:52 PM »
I was getting 53 -56 mpg or so on my wore out 836, on a 1900 mile trip.
Buddy riding with me on a stock K8 750 always bought more gas than me..
 Sometime we have folks on here struggling to ge better than 45 mpg.
Offline Lostboy Steve
« Reply #27 on: June 23, 2017, 02:42:08 PM »
That's why a lot of guys with rotary motors run them, because they work really well in the higher rpm areas and that's where the rotary (and most motorbikes) excel.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline krksquared
    • Nostalgic Kits Central
« Reply #28 on: June 23, 2017, 03:41:03 PM »
Webers can be great. I'm building a 428CJ for my 69 Mustang with them. They are 48IDAs. I used a 45DCOE on a Lotus years ago. Worked well but was a bit sensitive to altitude. Never thought about them on a bike.
@kennectwithme
1975 CB400F
1971 SL350
1979 CBX
2007 Buell XB9R
2003 Harley V-Rod VRSCA
If it ain't broke, I'm riding...
« Reply #29 on: June 23, 2017, 04:59:29 PM »
That's a lot of air moving right there.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #30 on: June 23, 2017, 06:46:25 PM »
Damn!  What a motor!
