Logo merchandise is available at the SOHC/4 Shop
Congrats Nick that is a great find ! You will have to share the story how you were able to uncover that gem.
HEY!That K3 has K2 gauges! It must be a real early K3!Out of curiosity: look at the starter solenoid, see if it has 4 terminals on its top.Also, look to see if there is the remains of a sidestand switch mount and/or a pair of wires hanging near the sidestand. This was parallelled to the clutch-lever START switch. They were all recalled and this switch removed, at one point in winter, 1973. A precious few of these early K3 bikes had these 2 items, where the 4-pole starter solenoid turned off the headlight instead of the later SPDT Start button (it had a grounding button, like the K2). The 2 extra terminals interrupt power to the 7 amp fuse on the fuseblock, if they are there.If so, it is a rare one, indeed!
Quote from: HondaMan on June 20, 2017, 09:03:52 PMHEY!That K3 has K2 gauges! It must be a real early K3!Out of curiosity: look at the starter solenoid, see if it has 4 terminals on its top.Also, look to see if there is the remains of a sidestand switch mount and/or a pair of wires hanging near the sidestand. This was parallelled to the clutch-lever START switch. They were all recalled and this switch removed, at one point in winter, 1973. A precious few of these early K3 bikes had these 2 items, where the 4-pole starter solenoid turned off the headlight instead of the later SPDT Start button (it had a grounding button, like the K2). The 2 extra terminals interrupt power to the 7 amp fuse on the fuseblock, if they are there.If so, it is a rare one, indeed!Here is a pic HM. It has 2 poles, then the 2 screws and 2 flat circular things. Sent from my SM-N920V using Tapatalk
Awesome find. Tresures found after the deal. A nice fulmer helmet in orange flake would set you apart.
Ok I gotta know, what'd you pay?
