Author Topic: Just like that, it all came to a halt...  (Read 1762 times)
Offline GardenGnome
  • 1977 CB550F
« on: June 24, 2017, 05:05:19 PM »
Was doing some removal of valves this evening and when i pulled the rubber bit i noticed a crack around the valve guide (not sure if that's accurate terminology). So I took the tip of my knife and lightly poked at it, it didn't take much and this is the result. I'm no expert, but I'd assume that I'm pretty well screwed at using this engine. Which really is a bummer because I was hoping to keep the original motor with the frame. That's not what I expected, but it's a drag I have to go looking for another motor.
If I've learned anything about building a motorcycle, it's check and re-check your work before you put it all back together. Although you do gain more experience by doing it twice.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: Just like that, it all came to a halt...
« Reply #1 on: June 24, 2017, 05:10:24 PM »
Valve guides are replaceable.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline innovativems
    • Innovative MotoSports
« Reply #2 on: June 24, 2017, 05:12:24 PM »
Pull the head and send it to Jmr porting.  Mreick is the man on here!
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
Offline GardenGnome
  • 1977 CB550F
« Reply #3 on: June 24, 2017, 05:17:31 PM »
Hmm, you don't say. Any sort of info on how to replace? or is that a job better left to a professional like what user innovativems suggested?
Offline Jimray23
    • none
« Reply #4 on: June 24, 2017, 05:20:25 PM »
Leave it to a pro
Jim
I really don't see why people ask for advice if their not going to take the advice given.
Offline GardenGnome
  • 1977 CB550F
« Reply #5 on: June 24, 2017, 05:22:03 PM »
Leave it to a pro
Jim
Duely noted. I'll have to see if any of the shops around here could handle that.
Offline Jimray23
    • none
« Reply #6 on: June 24, 2017, 05:24:07 PM »
Any decent engine shop should be able to do it.
Jim
Offline GardenGnome
  • 1977 CB550F
« Reply #7 on: June 24, 2017, 05:27:02 PM »
Quick edit. I was wondering why this had happened, turns out the valve that was in the place of the broken valve guide has a nice slight little bend to it, not that noticeable, but in all honesty the valve itself was a little bit of a, *clears throat* pain in the butt to remove. Now I get it, cause and effect. I'm just glad that I can still reused this part of the motor, that really makes me happy.
Offline GardenGnome
  • 1977 CB550F
« Reply #8 on: June 24, 2017, 05:30:23 PM »
Jim
I'll ask around, I know there's some out here. Just out of curiosity though, how come you don't recommend I do it myself?  Is there a particular degree the guide has to sit at? If I bought the part and brought it to the machine shop I would assume that would be acceptable and hopefully cheaper than having them buy it...I just don't know enough about what this all entails now. I was trying to avoid having to send the engine anywhere and rather have myself do all the work, but if this instance needs the touch of a professional then by all means I'm for it.
Offline Jimray23
    • none
« Reply #9 on: June 24, 2017, 05:33:59 PM »
It has to be lined up just right and made yo fit the valve with the  correct clearances. And I've heard stories of people pushing them through the head. You will probably have to order the guide or guides.
Edit: and the valves
Jim
« Last Edit: June 24, 2017, 05:36:59 PM by Jimray23 »
Offline Jimray23
    • none
« Reply #10 on: June 24, 2017, 05:35:59 PM »
I would say you got lucky. You might want to have the machine shop check for cracks while your at it
Jim
Offline GardenGnome
  • 1977 CB550F
« Reply #11 on: June 24, 2017, 05:50:23 PM »
Jim
Good call . I'll see what I come up with. Texting friends now who might be able to point me in the right direction of a good shop. Thanks to you guys too, if nothing psbs out locally I'll see about getting a hold of the guy  innovatiems suggested.
« Reply #12 on: June 24, 2017, 06:12:14 PM »
Turns out, I'm doing a valve guide replacement on my CB 550.
Head has to come off and be cleaned.
The head has to be heated so it will expand.  The guides are an interference fit into the bore of the head.
The guide is then driven out while the head is hot and expanded.  There is a driver tool for this.
The new guide is an interference fit, too.  Again heat the head and also freeze the guide to shrink it.
Drive the new guide into place with the driver.
Reheat the head for the next guide.
Now the new guide is reamed for proper clearance to the valve stem being used.
The valve seats now need to be re-cut. A three angle will do but a five angle is better. If doing just one , it should match the others.
The valve is then lapped for optimum seal.
The head is then reassembled and installed on the engine.
Simple, eh? ;D
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #13 on: June 24, 2017, 07:05:10 PM »
Simple, eh? ;D
They say if you can explain a complex process simply, you are a master of it.
« Reply #14 on: June 24, 2017, 07:20:57 PM »
Way easier sounding than when Soy Boy explains it..
Offline camelman
  • Man... Myth... Legend
« Reply #15 on: June 24, 2017, 08:00:39 PM »
Definitely a doable job. Might want to check all of your valves. The ends can mushroom if the rocker arm clearances get too large, and then scratch the inside of the valve guides upon removal or reassembly. Might have been what happened when you removed the valve from that guide, although with more dramatic results.
You can dress any mushrooming down with emory cloth. Just make sure to clean any residue off so that you don't scratch the guides.
I'm a fan of learning by doing, so I encourage you to do it! Good luck!
Camelman
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
Offline GardenGnome
  • 1977 CB550F
« Reply #16 on: June 24, 2017, 08:02:09 PM »
Simple, eh? ;D
Ha, I appreciate the simple breakdown of how the process is achieved. That being said, I do believe I will seek out a professional doing the task  ;D. Not that I'm lazy, just not ready for tackling this.
Question: since I have to replace the one valve guide, does it make sense to replace them all? Or should I just do the one(s) that need it? Follow up question, I read a thread about another member doing the same thing with valve guides. The thread stated that trying to find the OEM exhaust valve guide is a difficult. On 4into1 they sell the intake valve guide, however on the dynoman website it states that both the intake and exhaust valve guide are the same. Is this true for the OEM Honda ones from the 4into1?
« Reply #17 on: June 24, 2017, 08:11:53 PM »
Bent valves and guide damage on 550s are due to improperly installing the cam-cover; the tappet adjuster screws aren't centered over the tips of the valve stems, and the valves get bent as the cover is tightened down. One method to avoid this is to use rubber bands to hold the rocker ends up when the cover is installed.
Offline GardenGnome
  • 1977 CB550F
« Reply #18 on: June 24, 2017, 08:22:06 PM »
That's great to know. I'm not sure if this engine ever had any service done to it prior to me buying it, but it certainly seems like it didn't, I say that because of all the carbon build up. Of course to be honest, I'm not sure how long it would take for carbon to build up the way it did/is on my bike. I'm sure there's many factors that play into that.
Offline GardenGnome
  • 1977 CB550F
« Reply #20 on: June 24, 2017, 08:55:36 PM »
http://forums.sohc4.net/index.php?topic=82508.0
Whatever the equivalent to buying you a beer is for the internet, that's what I want to do for you sir! Did that come off as weird, I feel like that came off as weird...although sincere.
« Reply #21 on: June 24, 2017, 09:40:50 PM »
Cyber beer accepted. 8)
« Reply #22 on: June 24, 2017, 09:50:36 PM »
Simple, eh? ;D
I'm no master.  I haven't done it yet on the 550.  But, I do research before the doing.
  • Holy Cow! I'm a
« Reply #23 on: June 24, 2017, 09:53:22 PM »
The pre-77 550's will also muss up their valves when the rocker shafts get bored of boring in their factory bored bore.
Its all part of honda's self-destructing conspiracy
Offline GardenGnome
  • 1977 CB550F
« Reply #24 on: June 25, 2017, 07:27:53 AM »
I rally want to tackle this myself, just all the cutting of balves boring them, honing them, and even the process of uninstalling and installing just seems a bit much. Ive got a feeling the local guy who works on these old Hondas is going to tell me it's going to have to wait until winter. It's that or bring it to a major city and find someone to do it.
