Author Topic: Best fuel tank liner?  (Read 1613 times)
Offline evopgt
« on: June 29, 2017, 12:47:12 PM »
I know a mint tank with no liner is best. But if you have to... what's the best liner kit?? Kreem? Por15? Red kote? Northern? Gold standard? Any others?
Offline 540nova
Re: Best fuel tank liner?
« Reply #1 on: June 29, 2017, 01:08:19 PM »
POR15 never fails, if prepped and applied correctly
Sent from my SM-G955U using Tapatalk
« Reply #3 on: June 29, 2017, 02:24:09 PM »
Offline BallAquatics
    • https://vintage.dennisball.us
« Reply #4 on: June 29, 2017, 03:09:53 PM »
Have used Red Kote with great success.   8)
Dennis
Dennis...  74 CB550  79 CBX  82 Seca Turbo  2011 CBR  2012 NC700X
Offline innovativems
    • Innovative MotoSports
« Reply #5 on: June 29, 2017, 03:33:05 PM »
Caswell for me also
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
Offline jaytee-nz
« Reply #6 on: June 29, 2017, 05:32:25 PM »
Used POR15 many times with no issues - instructions must be followed to the letter though.
Offline m00ntan
« Reply #7 on: June 29, 2017, 05:35:16 PM »
Used Por15 about six years ago, no complaints and still shiny inside today.
CB750K4
CB550K1
CM400C
Offline carnivorous chicken
« Reply #8 on: June 29, 2017, 06:05:26 PM »
+1 of POR-15 -- never had a problem.
+1 on Red Kote, never had a problem and it's a 2-step process (POR-15 is 3 steps).
Haven't used Caswell but continue to hear good things about it...
Offline eigenvector
« Reply #9 on: June 29, 2017, 07:13:36 PM »
heard and seen nothing but bad things about Kreem.
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
Offline atm cycles
« Reply #10 on: June 29, 2017, 07:35:21 PM »
Por15. Used many times. Has lasted years.  I've had tanks done with other brands that have failed. I would chalk it up to improper prep. Prep is the key!!!!
« Reply #11 on: June 29, 2017, 07:46:44 PM »
Well here's a positive.
Did one many years ago with Kreem.  Did proper prep and let it dry with forced air for over a week.  It worked fine and never failed as far as I know.
I sold the bike after about 5 years.  Saw it again 3 years later and it was still good.
But, I did get all the rust out before use, followed the instructions, and had lots of time to let it thoroughly cure before ever putting fuel in it.
I have seen Kreem failures.  And in almost all cases they were done as rush jobs with poor prep.  Suspect the other failed cases were  poor prep, too, but unable to verify.  They had rust in them.  But, couldn't tell if it was from before or after the Kreem job.
« Reply #12 on: June 29, 2017, 10:29:57 PM »
My go to sealer is Caswell
+1
+1000 on Caswell -- Breakfast of Champions
I've had redkote fail.
Offline Lostboy Steve
« Reply #13 on: June 30, 2017, 02:40:08 AM »
Since he hasn't posted, I'll post on his behalf-
Pete'sPonies swears by Master Series Silver. It's a moisture cured product, seems to be about the same price as POR and Caswell. It converts rust and seals it and then becomes the finished layer. He swears by the stuff and has been using it for like 20 years rescuing Mustangs (and we all know what rust buckets those are).
I will try the product on a car project I have coming up, and a tank, but since you're a painter, thought you might also know it or want to investigate it.
I've also heard good things about that from the classic car guys.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
