Author Topic: Case boss by counter sprocket  (Read 1937 times)
Offline Johnny340
« on: June 30, 2017, 04:26:54 PM »
Is this broken boss just where the counter sprocket cover bolted to? I'm not sure I can run the stock cover anyway with offset sprockets so was thinking about ditching it. I guess that's two questions..
Sent from my SM-G930W8 using Tapatalk
1975 CB750F0 Super Sport
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
Offline disco
Re: Case boss by counter sprocket
« Reply #1 on: June 30, 2017, 05:12:52 PM »
Just for the sprocket cover.
1976 CB750 K6 Sapphire Blue
1972 CB750 K2 Candy Red
1972 CB750 K2 Candy Gold'
Offline Johnny340
« Reply #2 on: June 30, 2017, 05:14:10 PM »
Ah, I see that from your pic. Any problems not running that cover?
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
Offline disco
« Reply #3 on: June 30, 2017, 05:23:01 PM »
The sprocket cover uses two bolts to secure it. The bolt hole at about 11 o'clock above the sprocket, is the 2nd fixing point. I think you could still run the cover OK with only one bolt.
Why not JB Weld it? Selley's 'Knead It' etc?
« Last Edit: June 30, 2017, 05:26:54 PM by disco »
Offline Johnny340
« Reply #4 on: June 30, 2017, 05:26:48 PM »
The sprocket cover uses two bolts to secure it. The bolt at about 11 o'clock above the sprocket, is the 2nd fixing point. I think you could still run the cover OK with only one bolt.
I see. I'm still thinking I don't want to run the cover because the chain will interfere running on offset sprockets..
Does someone make a plug so crud won't go down the hole into the shift mechanism?
« Last Edit: June 30, 2017, 05:55:47 PM by Johnny340 »
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
« Reply #5 on: June 30, 2017, 09:57:03 PM »
That usually has your wires in there.
Offline Johnny340
« Reply #6 on: June 30, 2017, 10:05:19 PM »
Will that be enough to block off that hole? Am I crazy to run without the cover in place?
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
« Reply #7 on: June 30, 2017, 11:06:40 PM »
Cover protects against dirt and grease. I should repair it with a good chunk of JB weld, make a new threaded hole, probably with a thread insert glued, time-sert
« Reply #8 on: July 01, 2017, 09:26:28 AM »
You can cut part of your sprocket cover off, including the lower bolt part... Super easy to put in, still keeps the Mungue off everything..
Offline Johnny340
« Reply #9 on: July 01, 2017, 09:31:31 AM »
I like that idea! Solves both problems. 👍
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
« Reply #10 on: July 01, 2017, 09:58:57 AM »
I think it was a mostly vertical cut.
Offline Johnny340
« Reply #11 on: July 01, 2017, 12:47:22 PM »
Yes, this should work. Thanks for the suggestions!
I don't need much of an excuse to take it the new plasma cutter..
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
« Reply #12 on: July 01, 2017, 01:08:50 PM »
If it gets too dirty, cut the next one from top right corner..straight down.
Looks good though..
Offline disco
« Reply #13 on: July 01, 2017, 05:55:06 PM »
Nice job! I now know what I'm going to do with my old sprocket cover with a divot out of it ;)
« Last Edit: July 01, 2017, 06:00:22 PM by disco »
