Aggghhhh, I read it too fast
Cylinder Block you say
The only change in the K cylinder blocks that I am aware of is when they added the knock pins(74 model, I think
). These are the 8 dowels and seals that fit in the oil passageways between the cylinder BLOCK and cylinder HEAD. There are recesses in the cylinder block for these dowels and seals to fit in.
You can use any year SOHC K model cylinder block on your 75 engine. If you use a block with knock pin recesses(74-78) then you just need to make sure that you have the knock pins(dowels) and seals as well.
