Author Topic: Anyone used an M-unit blue?  (Read 1628 times)
Offline bomorr
    • sohc/4
« on: June 30, 2017, 07:14:33 PM »
Just saw that motogadget release a new version of the M-unit called the M-unit Blue. Has Bluetooth connection enabling diagnostics and proximity key switch when it connects via Bluetooth to your phone. Wanted to see if anyone has used this version yet?
https://revivalcycles.com/collections/motogadget-motorcycle-parts/products/motogadget-m-unit-blue
Sent from my SM-G950U using Tapatalk
Re: Anyone used an M-unit blue?
« Reply #1 on: July 01, 2017, 12:55:48 AM »
A few out in the wild.  Dave Hargreaves at Cerberus Moto in San Diego. Revival in Austin.
Offline DaveBarbier
« Reply #2 on: July 01, 2017, 04:39:13 AM »
There is a member who is just in the middle of wiring one up I believe, I forgot who.
Are you looking to get feedback or just curious who's using it?
Offline bomorr
    • sohc/4
« Reply #3 on: July 01, 2017, 04:43:08 AM »
Both, I've got two projects and I have the V2 m-unit for one. Just wondering if the blue unit is worth the extra cash. I really like motogadget gear but they are so damn expensive!
Offline ChopSticks
« Reply #4 on: July 01, 2017, 06:33:30 AM »
Heard the Blue is a bit bigger, and also wires feed to the top which might require more mounting room
« Reply #5 on: July 01, 2017, 08:32:45 AM »
I don't know how much larger it is if any, but the wires do mount in from above, so it needs a wee bit more head space.
Specs:  90 x 53 x 30 mm, bolt distance 74 mm
https://motogadget.com/shop/en/m-unit-blue.html
See manual attached (below)
Offline bomorr
    • sohc/4
« Reply #6 on: July 01, 2017, 12:28:23 PM »
There was one thing that caught my eye when watching revivals videos on this. They said there is a line bus opening which means at some point motogadget is going to make future gauges etc that can take a bus line without using the mbutton. That would clean up wiring even more.
