Author Topic: Does anyone know what year/K model CB750 that #064 round-top carbs are from ?  (Read 1279 times)
Offline grcamna2
I just wondered because I have access to a set.
Offline grcamna2
Thank you Lloyd  :)  1975-76 CB750F0-F1
Offline grcamna2
 It shouldnt really matter much which version from 71-76 you get. Slight differences in jetting and needle settings.. Hondaman would know if there are slide changes.
 You may want to change to dual hose gas feed if your petcock uses that.
I should mention, main idle adjust (big knurled screw) is on right side after 75.
You can switch the rack if you have the other style.
« Last Edit: July 01, 2017, 07:48:59 PM by 754 »
1975 CB750F
http://www.motorcycleproject.com/text/specs.html
What does "JN" mean?
Jet Needle
Its the needle in the slides.  The number relates to the clip position specified.
