Author Topic: Led turn signals  (Read 3877 times)
Offline MD
  • Living in the North Woods overlooking The Lake.
    • MN North Woods
Led turn signals
« on: July 01, 2017, 05:36:15 PM »
'75 CB550F Super Sport
In order to make power available for some auxiliary lights I switched the turn signals to 1156 & 1157 Sylvania LEDs.  I also replaced the stock flasher with a LED compatible unit.  First I tried an AUDEW 2-Pin.  Turn signals would not flash, adjusting the potenteometer did not help.  I then tried iJDMTOY (1) 2-Pin Electronic LED Flasher Relay.  When turning on the signal the light brightens but does not flash.  Turning the signal on originally caused the oppisite running light to go out.  After flipping the flasher leads both running lights remain lit.
This bike does have the original 2 light left & right indicator.
Steps taken,
Check connections and grounds front and rear.
Disconnect the beeper,  no change
Disconnect the rear lights, no change
Flip the running and turn leads for the front lights.  Running lights are brighter but signals still don't flash.
Other than giving up and going back to stock lights,  what should I try?
Thanks.
-MD
1975 CB550F Super Sport;  Lake Superior Circle 1000, 45-90 Saddle 1000, All in Yooper 1000 and SS 2000 in 48 hrs:  1985 GL1200A, MN in State SS1K
Offline Airborne 82nd
Re: Led turn signals
« Reply #1 on: July 01, 2017, 06:11:10 PM »
Steps taken,
Thanks.
-MD
Considering the amount of time the turn signal is on I don't see you gaining much if any additional power
Offline MD
    • MN North Woods
« Reply #2 on: July 01, 2017, 07:36:27 PM »
Airborne 82nd
The front LEDs are on all the time as running lights.  I also replaced the tail light with an LED.  The stock headlight was swapped out with a halogen 35/50.  All these changes have dropped the running voltage from bike needing 9.6 amps @5000 rpm to 8.8 amps @5000 rpm.  This will give me .8 amps of available power without overloading the bikes charging system.
-MD
Offline MD
    • MN North Woods
« Reply #3 on: July 02, 2017, 06:04:24 AM »
Did you try swapping the poles on the flasher unit?
Calj737
Yes,
I can't find the thread that we discussed the leads feeding the buzzer.  Do you just tape them off or do you put a jumper between them to complete the circuit?
On an older car non flashing lights would indicate it was a bad bulb, not the case on the bike.
Next thing I try is opening up the bucket again and unplugging the front lights.
Thanks,
-MD
Offline evopgt
« Reply #4 on: July 02, 2017, 10:25:22 AM »
The issue I had with my led turns is a lack of a defined on/off blink even with a new electronic LED flasher. I wired up 4 in line resistors and they worked wonderfully. I still hate the thoughts of all of the wiring for resistors and the extra mess under the seat. I m going to try a different flasher, if it doesn't work, the resistors are getting installed. I picked up 4 on eBay for like 8.68 shipped to my door. Don't use the supplied t connectors though, they can cause connection issues.
Offline evopgt
« Reply #5 on: July 02, 2017, 10:32:07 AM »
I should also note.  I wired the fronts to just be turn signals .. not on all the time and I abandoned the buzzer and all of the dash dummy lights. The only non led light on the bike will be the halogen headlight. It will just have a lighted up speedo. Only went with what is needed.
« Reply #6 on: July 02, 2017, 10:35:18 AM »
Chip resistors take very little space.  I can't see your physical arrangement, though.
Why can't you just solder one to the LED?
Offline MD
    • MN North Woods
« Reply #7 on: July 02, 2017, 02:17:21 PM »
TwoTired,
In my case the bulb bases are standard bonnets with 1 or 2 feed points and the outside of the bonnet as ground.
-MD
Offline MD
    • MN North Woods
« Reply #8 on: July 02, 2017, 03:20:08 PM »
I have ordered replacement LED BA9S for the dash indicators.
-MD
Offline millla03
« Reply #9 on: July 02, 2017, 08:16:58 PM »
The problem I encountered going to full LED was the signal backfeeding through the "idiot" or indicator light on dash. It needed diodes wired in between the power feeds to this light with the other wire connected straight to ground.
If you disconnect the dash indicator light and the signals then function, diodes should do the trick without needing resistors. Free and easy to try.
« Last Edit: July 02, 2017, 08:36:21 PM by millla03 »
Luke
72 Honda CB750 K2
78 BMW R100/7
83 Honda Nighthawk 650
07 Honda Rebel 250
Offline evopgt
« Reply #10 on: July 03, 2017, 10:13:12 PM »
Update on my problem, I tried another flasher. It was an adjustable 2 pin flasher.  It got them to blink, but, the left would be faster than the right and if the adjuster moved even the slightest from where I got it to work. The left didn't blink at all..I didn't like it. So I wired up the resistors tonight, I love how they work now!!
« Reply #11 on: July 03, 2017, 11:14:17 PM »
Not trying a 3 wire/terminal flasher for leds?
How many lumens are the sylvania Leds cranking out?
Mcm electronics has $4 shipping on most orders through Tuesday.
David
Offline MD
    • MN North Woods
« Reply #12 on: July 05, 2017, 06:36:31 PM »
David
David,
I looked on the packaging and could not find the lumens listed.
Replaced the dash indicator lights with LEDs.  Lights still don't flash.  I'll take Dave's advice and try a three wire.
-MD
Offline MD
    • MN North Woods
« Reply #13 on: July 10, 2017, 02:54:25 PM »
The Three wire flasher works in lane change mode.  In other words if you push the switch to lock position the signals won't flash.  If you hold the switch engaged prior to the lock lights flash.  I looks like I will need to clean that switch.
-MD
Offline Mr.D
« Reply #14 on: July 13, 2017, 10:18:38 AM »
I just encountered the same problem. Last week I replaced all bulbs except the two rear signals with LEDs...(because I ordered the wrong bulb for rear signals the first time)... ((oh, the headlight is still an incandescent sealed-unit as well))... Installed a two-prong adjustable electronic flasher, and all was working well. Great! I thought.
Today got the proper LEDs for the rear signals, installed them, and lo and behold, no flashing any more.  :-\
The electronic flasher claimed to be able to eliminate the need for resistors. I don't know whether to try another electronic flasher or what. It was pretty cheap but obviously don't want to keep ordering parts that aren't going to work!
Any new hints/success stories?
1977 CB550F
Offline millla03
« Reply #15 on: July 14, 2017, 09:10:56 AM »
Did you try the flashers with the idiot light unplugged? I just went through this a few months back and the issue I described above was at fault. Worth a shot and costs nothing to try. I'd be happy to provide info on wiring diodes into the circuit if needed.
Luke
72 Honda CB750 K2
78 BMW R100/7
07 Honda Rebel 250
« Reply #16 on: July 14, 2017, 09:21:44 AM »
The electronic flasher claimed to be able to eliminate the need for resistors.  For new/modern electrical systems, sure. I don't know whether to try another electronic flasher or what. It was pretty cheap but obviously don't want to keep ordering parts that aren't going to work!
Any new hints/success stories?  Run standard bulbs in either your front or rear signals and move on  ;D
Offline Deltarider
« Reply #17 on: July 14, 2017, 11:22:58 AM »
+1 or better: run them in both. In 37 years I had to replace one such a standard bulb. Let's assume PO also replaced one. Cost in total: less than $ 1,-. Not much for a dead reliable item that is better noticed (glow on glow off) is noticed from the side as well, doesn't need a special reflector, nor extra wiring, nor diodes, nor a different relay and can be bought in practically every pop and mom store. Tip: go for 21W max or 18W, preferably with an E-approval. Philips used to have them that drew less current, but I haven't seen them for a wile. You could also choose 15W halogen that live even longer.
« Last Edit: July 14, 2017, 11:41:21 AM by Deltarider »
CB500K2-ED Excel black
Offline MD
    • MN North Woods
« Reply #18 on: July 15, 2017, 08:31:58 AM »
Figured out the final culprit.  :)  I opened up the switch and cleaned the contacts but that did not solve the problem.  Opened the bucket up and disconnected the buzzer again.  I now have blinking lights in the lock position.  It appears the buzzer acts like the single indicator light in other bikes.  If I want to use it I will have to isolate the direction of the power flow.  For now I will not use the buzzer.
Flasher unit used:  Lsgoodcare Car Turn Signal Blinker Light 3Pin Adjustable Electronic LED Flasher Relay
-MD
Offline evopgt
« Reply #19 on: July 15, 2017, 10:17:02 AM »
MD.   Did your bike originally have a 2 pin?? Did you just use the extra flasher terminal on the 3 pin that most bikes come equipped with?? How did you determine which wire goes to which terminal on the flasher?? I may try this so I can get rid of the resistors.  Thanks.
Offline MD
    • MN North Woods
« Reply #20 on: July 15, 2017, 03:44:31 PM »
The bike came with a 2 pin flasher.  There is a extra ground wire not used near by.  The ground was easy to figure out.  The other two wires were a bit of trial and error.  In the picture below you can see the color progression of the wires.
Good luck,
-MD
Offline Mr.D
« Reply #21 on: July 16, 2017, 11:49:02 AM »
Thanks for the suggestions guys. You're right it's not a big deal to leave in the old bulbs, especially in the rear signals that aren't on all the time as running lights. I might just leave them there and call it "good enough"! \
It was never about saving money or not having to replace bulbs (in fact it's a heck of a lot more money to use LEDs!), it was always just about having less draw on the electrical system.
1977 CB550F
