Author Topic: Way high RPM after carbs rebuild  (Read 11193 times)
Re: Way high RPM after carbs rebuild
« Reply #100 on: July 12, 2017, 12:53:22 PM »
What you haven't polished your condensers?  What a rookie!
Just kidding...
Timing looks good me if that alignment was the transition from dark to light.
Did you set the point gap first?
Offline Can550
« Reply #101 on: July 12, 2017, 12:56:25 PM »
Just kidding...
Yes I did to 13
Offline Can550
« Reply #102 on: July 12, 2017, 01:00:09 PM »
Oh by the way just noticed/ remembered, while the test light comes ON on F1-4, I just removed test lamp and connected to 2-3 and it lights up. Some f^*+ up or normal
« Reply #103 on: July 12, 2017, 01:11:50 PM »
Points cam is designed to close each contact for 190-ish degrees, leaving an overlap.  This is dwell time or the time spent charging up the coils.
I do new points to 0.016 Thou.
Wonder if you have a bad cam or something bent.
Have you removed the timing advancer?
Offline Can550
« Reply #104 on: July 12, 2017, 01:16:31 PM »
No I have not removed advancer
How do I find out if cam is bad ?
« Reply #105 on: July 12, 2017, 01:38:42 PM »
If the cam surface is smooth and not grooved, it's ok.
The shaft that it is mounted on could be bent.
You should check the run out of the shaft under the cam.
Rig up a rigid wire pointer near the shaft and rotate the crank.  The pointer to shaft distance should remain the same throughout crank rotation through 360 degrees.
Offline Can550
« Reply #106 on: July 12, 2017, 01:57:21 PM »
Ok
Got it
Ran again
Starts only with choke
The moment choke is returned, shuts
Should I lube the wick on points plate, seems dry. Engine oil is ok ?
« Last Edit: July 12, 2017, 01:59:16 PM by Can550 »
« Reply #107 on: July 12, 2017, 02:16:26 PM »
Ok
Got it
Ran again
Starts only with choke Typical
The moment choke is returned, shuts .   turn IN the idle set screw to keep RPM at 1200
Should I lube the wick on points plate, seems dry. Engine oil is ok ? yes, but only a little
Offline Can550
« Reply #108 on: July 12, 2017, 02:22:05 PM »
That's good.  Be nice to verify with an ohm meter, the end to end resistance, plug cap connection to plug cap connection for each coil.
S/B ~ 25-35KΩ.
Have you looked at the spark system in the dark to see if there is visible arcing?
[/quote]
Am I doing it right ?
« Reply #109 on: July 12, 2017, 02:30:06 PM »
If that cap is rated 5K ohms...its going bad.  IIWM id replace it.
You'll find the rating stamped on it.
5K caps should read 4.7-4.9K ohms when new
Offline Can550
« Reply #110 on: July 12, 2017, 02:35:31 PM »
I also checked plug cap to plug cap for 1-4 and 2-3
Respectively it is in following photos ( if it makes any sense)
« Reply #111 on: July 12, 2017, 03:00:55 PM »
S/B ~ 25-35KΩ.
[/quote]
No.  The black plug should be in the COM socket on your meter.  Al your measurements are invalid.
Do you read the meter's operation manual?
« Last Edit: July 12, 2017, 03:03:24 PM by TwoTired »
Offline Can550
« Reply #112 on: July 12, 2017, 03:33:57 PM »
Sorry Two Tired
I did read the manual and by mistake switched the black connector.
However when back in to COM port coil 1-4 reads 31.7 and spark plug cover reads 8.3
« Last Edit: July 12, 2017, 03:47:38 PM by Can550 »
« Reply #113 on: July 12, 2017, 04:12:02 PM »
Almost certainly, your other plug caps were 10K -ish when new and were good for 20% tolerance + or - (that's 2KΩ).  Years of current through them has likely fused some of the carbon pile resistors inside, which lowers the resistance.  Probably should check the others, just to know.
I don't know where to find replacement 10 K caps, apart from used.  I prefer these for the 550.  But the industry has switched to resistor plugs (5K) and so the 10K caps are out of favor for the manufacturers who now only make 5K caps.
Either will work, and what you have will work ok.  The big thing is that the caps don't read open circuit or infinity resistance.
Your end to end test of the coils show they are ok for continuity, and should produce the required voltage to spark the plugs.  Carefully inspect the lead insulation for cracks.  That will let the spark voltage out and make a path to engine block/frame.  Easier to see that action in a darkened garage.
Still need to check the runout on the point cam shaft, before declaring the ignition system operable.
Offline Can550
« Reply #114 on: July 13, 2017, 08:46:44 AM »
Good morning
Opened up valve/tappet covers and checked clearance adjustments. All seemed fine except inlet of #2 and exhaust #3. Now I am confident that all are properly adjust as I checked twice.
I haven't been able to figure how to bench sync while carbs are in the bike.
If I drop all (pistons) sliders to reach bottom and then raise with idle adjuster ?
Thanks
« Reply #115 on: July 13, 2017, 09:15:11 AM »
Good morning
Opened up valve/tappet covers and checked clearance adjustments. All seemed fine except inlet of #2 and exhaust #3. Now I am confident that all are properly adjust as I checked twice.   Great!
I haven't been able to figure how to bench sync while carbs are in the bike. For the sake of accuracy, you should take them off :-\ First reset all vac adjuster screws to mid-travel, and then bench sync the slides.
Thanks
Offline Can550
« Reply #116 on: July 13, 2017, 10:36:30 AM »
Damn
Came up to bike, re filled aux tank (hanging from ceiling) as I turned the gas ON, #3 carb bowl overflow started leaking. This thing is giving me so much grief
Now I'll pull the carbs out
« Reply #117 on: July 13, 2017, 10:44:26 AM »
if they didnt overflow last time, just bang on the carb mount plate to free up the floats.
Offline firebane
« Reply #118 on: July 13, 2017, 11:49:56 AM »
Damn
These bikes are stupid sensitive on the floats. It took me forever to get to a point where mine would not leak badly. My 1 and 3 were really bad but I'm confident they are good now.
How I did my bench sync was this.
1. Adjust idle screw completely out
2. Use individual slide adjusters to lower the slides to the floor
3. Turn in idle screw and watch which slide moves up first (Use this as your master); Only want a slight movement.
4. With 1/8" drill bit on the master slide adjust with adjuster screw till it just fits in then lock down nut
5. Proceed to adjust the other 3 the same way
Once completed you should be able to back out your idle screw and all slides will touch the floor and cause a stall if you do this. Adjust idle screw back to where a 1/8 bit will just fit and this should be a good base.
Offline Can550
« Reply #119 on: July 13, 2017, 01:24:00 PM »
Thanks firebane
I removed the bowl of #3, moved (carefully) float up and down put the bowl back on. Connected fuel and it leaked again, tapped on sides (as you suggested) it stopped leaking :)
Carbs are still in bike. I'm avoiding taking them off as lately too much time has gone in to all this. Probably in a day or two if I'm back to the spirit and time.
Much appreciated and thanks once again
Offline Oddjob
« Reply #120 on: July 13, 2017, 02:18:32 PM »
If your using DR7EA plugs then those are resistors plug and shouldn't be used with high resistance plug caps, can't remember offhand what the resistance should be but to be safe get some D7EA plugs.
Altering 1-4 timing WILL alter 2-3 timing, the plate 2-3 sits on is bolted to the backplate, as you rotate the plate to get the timing for 1-4 right you'll alter the timing for 2-3 as that's moving as well, get 1-4 right and then do 2-3, that's why it has a separate plate.
Offline Can550
« Reply #121 on: July 13, 2017, 05:33:06 PM »
Thanks Oddjob
Did some forum search on DR7EA vs D7EA and found some discussion on same subject. It states that DR7EA will work but life will be half compared to D7EA. The very fact you noted since these are R resistance packed 5ohms once these build more resistance, will demand/ need more power that coils will be unable to deliver. So I guess I'll keep them for now (meantime will order D7EA).
If it is going to make a difference in my initial tune up/ sync, then I'll wait to do it till I receive.
Had adjusted timing already with two separate plates adjustment. I'm not on the dot despite trying several times. Just a tad off, I'll say 99.5% accurate.
1-4 fires up just a hair before F and 2-3 fire up right on F.
Offline firebane
« Reply #122 on: July 13, 2017, 05:35:27 PM »
As long as you use 5k caps with R type plugs you will be fine.
Offline Can550
« Reply #123 on: July 13, 2017, 05:38:08 PM »
But being stock, my caps are to be 10k
Offline firebane
« Reply #124 on: July 13, 2017, 05:39:58 PM »
Possible but never assume unless you have verified. My bike had a hodge podge of caps and plugs and the bike would just not run right. Put proper plugs and caps and runs like a champ.
