Author Topic: Way high RPM after carbs rebuild  (Read 11091 times)
Re: Way high RPM after carbs rebuild
« Reply #25 on: July 07, 2017, 12:27:22 PM »
What is the opinion on
Motion Pro 08-0411 Syncpro Carburetor Tuner
Poor quality...
Go with one of these.
http://www.saber-cycle.com/store/product735.html
https://www.carbtune.com/
« Reply #26 on: July 07, 2017, 12:29:20 PM »
I have the ones from Saber Cycle.  They are well made and I have successfully used them for years.
Offline Can550
« Reply #27 on: July 07, 2017, 12:30:43 PM »
Thanks
Things are over the top here in that case
Prices starting over 150$ (Canadian)
« Reply #28 on: July 07, 2017, 12:46:14 PM »
I like the gauges.  My set from 1975 is still my go to set.
The set you mentioned (Motion Pro 08-0411 Syncpro Carburetor Tuner), might work ok for the short term.  But, it doesn't look like it will last.  Maybe you're ok with that.
It is certainly better than nothing at all!
Offline firebane
« Reply #29 on: July 07, 2017, 12:55:45 PM »
Thanks
You can pickup a set of the 4 gauge vac sync tool from ebay for $50-60 US if you look around.
Offline Can550
« Reply #30 on: July 07, 2017, 06:28:35 PM »
Offline Can550
« Reply #31 on: July 07, 2017, 06:32:57 PM »
Would appreciate to have experienced opinion
Offline Can550
« Reply #32 on: July 07, 2017, 08:59:20 PM »
Offline Can550
« Reply #33 on: July 09, 2017, 06:45:54 PM »
I found this one on Amazon.ca what is the general opinion
« Reply #34 on: July 09, 2017, 07:52:12 PM »
sounds like you need to do a valve adjustment, cam chain adjustment, and then a vac sync. ;D
Offline Can550
« Reply #35 on: July 09, 2017, 08:34:25 PM »
Thanks flybox
I shall now adjust tappets/ valves and chain tensioner per manual and then get a set of vacuum gauges to sync carbs.
It feels like doing these two adjustments shall make difference how bike sounds ?
Offline Can550
« Reply #36 on: July 09, 2017, 08:36:01 PM »
On the same note,
(After carbs rebuild)turning choke is pretty hard it sort of locks in somewhere. Can't figure out how to fix it. Did some search and didn't come across any thread/ post.
When chocking, it's very hard to move up (used leverage of a screwdriver) from open position, bringing down to running position, feels like a spring resistance.
« Reply #37 on: July 09, 2017, 09:04:15 PM »
Did you remove the carbs from the joiner plate?
Choke binding can happen if they didn't get aligned right on the joiner plate.
Did you remove the choke plates from the carbs?  If the plates didn't get put back in the same place they can bind in the bore.
Offline Can550
« Reply #38 on: July 09, 2017, 09:07:58 PM »
Yes I am sure it/ plate was removed (as this job was done by someone) God I hope I don't have remove carbs ;(
Offline Can550
« Reply #39 on: July 09, 2017, 09:09:41 PM »
Sorry but if you are asking about flaps (butterfly looking plates) or the main plate on which all four carbs attach?
I'm not certain if flap/ plates were removed.
Offline Can550
« Reply #40 on: July 09, 2017, 09:18:40 PM »
But initially it was not hard like it was today, though there was some hesitation present before
Offline Can550
« Reply #41 on: July 09, 2017, 10:09:31 PM »
Terribly sorry but should I do valve adjust then chain tensioner or otherwise ?
Offline firebane
« Reply #42 on: July 10, 2017, 08:50:15 AM »
Looking at airbox side of your carbs there are little adjustment screws and tabs for each of the butterfly valves. If this are not seated correctly they will fight against one another and not function properly. Using a screwdriver to work them is also very bad and could cause twisting or bending of parts which should not.
And yes you should adjust the valves, tensioner then do a sync because all the internal mechanicals have to be functioning together to run properly and if they are not the synch process will not be accurate.
« Reply #43 on: July 10, 2017, 08:59:31 AM »
I prefer (on a cold engine) the cam chain adjustment, first, and then a valve adjustment.
These, and a good vacuum sync will quiet your engine.
Offline Can550
« Reply #44 on: July 10, 2017, 09:15:12 AM »
Loosening the locknut of cam chain tensioner didn't change the screw/ stud at all. Does it mean it's on right spot or something else
Offline firebane
« Reply #45 on: July 10, 2017, 09:16:52 AM »
There is a very specific way of setting the tensioner that needs to be followed. You can't just undo the nut and have it be correct.
Needs to be 15 degrees past TDC #1
Offline Can550
« Reply #46 on: July 10, 2017, 09:26:38 AM »
Yes I did it 15 degree past TDC #1 as per manual. When the lob of spring is just past the line/ marking
Offline firebane
« Reply #47 on: July 10, 2017, 09:33:25 AM »
Using a screwdriver and wrench can you undo the nut?
Offline Can550
« Reply #48 on: July 10, 2017, 09:50:58 AM »
Undoing locknut wasn't a problem. It came loose but the screw inside the locknut (my understanding that it should move a bit itself) didn't move
« Reply #49 on: July 10, 2017, 09:57:11 AM »
@ 15deg past TDC
-undo the lock nut
-back out the retaining bolt so the cam chain plunger is free
-snug the retaining bolt back in to lock the plunger back in place.
-tighten down the lock nut.
done.
If the cam chain tensioner has never been serviced, it might be best to take out the three bolts, pull out the unit, and clean/grease it well.
Look for a depression in the plunger rod, and fix as necessary.
The plunger should move freely in the tensioner.  Old grease there can prevent it from 'tensioning' the cam chain as the plunger spring is kinda weak.  :P
« Last Edit: July 10, 2017, 09:59:15 AM by flybox1 »
