Author Topic: Restoring a master cylinder  (Read 1138 times)
Offline Keith
« on: July 04, 2017, 07:47:34 PM »
I looked through FAQs, but didn't see this topic. How would you restore the finish on an original master cylinder? (Black) thanks for any suggestions.
Re: Restoring a master cylinder
« Reply #1 on: July 04, 2017, 09:01:18 PM »
The originals were anodized black.
Offline Dunk
« Reply #2 on: July 09, 2017, 05:29:06 PM »
Originals were anodized. I used caliper paint on mine. Just need to be careful about brake fluid. Are the David Silver repops anodized and original looking?
Offline MattCB750K8
« Reply #3 on: July 09, 2017, 05:38:58 PM »
I just finished rebuilding mine. I used gloss caliper paint. I'll post up a pic tomorrow. came out very nice.
I lightly honed the bore first.
Degreased and cleaned it several times to make sure I avoided fish eyes,
Plugged and masked all the holes plus the cap threads.
Finally degreased and cleaned it several times to make sure I avoided fish eyes, Sprayed and let it dry a couple days. I gave it plenty of time to dry before I rebuilt it.
I don't know of any truly dot3/4 resistant paint. Caliper paint is usually for temp not fluid resistance. Powder coating may be another option, again prep work would be the same but even more important to mask areas when you don't want build up.
Works and looks nicely.
1978 CB750K
Stock except for 4 into 2 exhaust
Offline Keith
« Reply #4 on: July 09, 2017, 08:23:46 PM »
Thanks guys! I was wondering about paint or finding a shop to re-anodize.
Offline texianbiker
« Reply #5 on: July 15, 2017, 01:11:04 PM »
I de anodized my K0 master cylinder and cap with Easy Off oven cleaner then had both powder coated matte black.  The look is OEM new and the powder coat is more brake fluid resistant than paint and more fade resistant that the dye used to anodize.
Offline Scott S
« Reply #6 on: July 15, 2017, 01:30:53 PM »
 Here's how I've been rebuilding/restoring them lately.  8)
https://www.davidsilverspares.com/CB550K1-1975-USA/part_123904/
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Ujeni
« Reply #7 on: July 15, 2017, 08:43:38 PM »
If you have them re-anodized make sure your anodized uses the correct chromic method. The more-common sulfuric method will result is a dull finish.
Ujeni Motors
Sandcast #410
Sandcast #538 Watch the restoration!
Sandcast #6592 All original daily driver.
