Author Topic: Newish rider upgraded to CB750K8  (Read 1031 times)
Offline MattCB750K8
« on: July 05, 2017, 04:12:04 PM »
Been reading articles on here for a while, but without a CB seemed useless to join.
Been riding my 09 Suzuki TU250X for several years and decided it was time to step up to a little more road capable bike.
I have been considering a 500cc + bike for a year or so, I love the vintage look. I considered a 70's CB550/750, Triumph Bonneville T100, Royal Enfield Classic.
I originally was looking for 50,s bikes like AJS/Matchless Twins or Vintage Norton Commando and Triumph.
My dad convinced me to think of a slightly more modern bike, with electric start, modern type controls and a disc brake.
He rides a couple of newer Bonneville's (And he is 83) and in the past had a 1948 Triumph Speed Twin, CB550, BSA Royal Star, so I trust his advice.
I Hmmmed and hawwed a lot on the Royal Enfield Classic but the idea of another thumper kind of soured me, although it had the looks. Newer Triumph T100's have kind of the look I like.
I bought a nearly unmolested 78 CB750K8, everything original ( Except the 4 into 2 exhaust) and runs perfect, all electrics work and rode nicely.
I have decided to put a few hundred dollars and time into maintenance, new tires, rebuilding the brakes, etc.
The PO had the carbs rebuilt and synced. Kicks the first time even cold, idle rises after a few minutes. He had it idling a bit high, so I adjusted it to idle about 1050 when warmed up.
The tires where VERY old continentals 3.50/4.50 that had dry rotted badly, the front brake is hanging a little bit causing drag on the nose.
Today I ordered everything to completely rebuild the front and rear brakes, MC, Hydraulics, fluid change. also a new oil filter kit etc.
For tires I ordered the Metzler Lasetec's, mostly because the front is the correct 3.50-19 instead of the 100/90-19 which in my research is not even close to a 3.50-19 and I was able to match it to a 130/90-17 which is very close to original size. Both have the correct sidewall profile and are approved for the 1.85/2.50 rims.
I plan on keeping her stock as she is now. If I do like her a lot I may look for a CB550 or an earlier CB750, this is after all dipping my foot into the larger bikes.
Just want to say there is definitely a wealth of info here and I thank all that contribute their knowledge.
Matt
1978 CB750K
Stock except for 4 into 2 exhaust
Offline MD
  • Living in the North Woods overlooking The Lake.
    • MN North Woods
Re: Newish rider upgraded to CB750K8
« Reply #1 on: July 06, 2017, 05:47:44 PM »
Welcome from MN,
Remember that other members like to see pictures of your bike.
-MD
1975 CB550F Super Sport;  Lake Superior Circle 1000, 45-90 Saddle 1000, All in Yooper 1000 and SS 2000 in 48 hrs:  1985 GL1200A, MN in State SS1K
Offline MattCB750K8
« Reply #2 on: July 06, 2017, 09:45:43 PM »
Ahh yes the all important photo op.
CB750k8 and pops 09 Bonneville in the background.
1978 CB750K
« Reply #3 on: July 07, 2017, 07:12:57 AM »
Welcome from Texas.  I had one just like that but mine had the original exhaust.
BTW - pretty sure the OEM front tire was 3.25-19", but 3.5 will be fine.  I run a 100/90mm on my K4....
Offline MattCB750K8
« Reply #4 on: July 07, 2017, 08:59:51 AM »
I spent a few days researching the front tire. in 77 they gave the CB750k a bump from 3.25 to 3.5, my manual also states the tire is a 3.5.....your right either are fine though as its the same 19" 1.85 rim as the k6 and earlier.  The funny issue is though, a 100/90-19 is supposed to be equal to the 3.5, but all the manufacturers data says the 1.85 rim is not approved for it and a 2.15 is the minimum. Its probably not a big deal though as I have read most run the 100/90 with no issues.
1978 CB750K
« Reply #5 on: July 07, 2017, 02:19:23 PM »
Very clean K8  8)
Welcome from Seattle....
Offline Desert-SOHC
  • It's old
« Reply #6 on: July 07, 2017, 02:32:49 PM »
Howdy...78's are the fastest...... :P
If you want to get rid of those pipes...I call dibs!
90 F350 Lariat CS S/C Dually
90 S&S 11SC Cabover Camper
97 FLHTP (under construction)
11 Ranger S/C 2wd
« Reply #7 on: July 07, 2017, 06:08:18 PM »
Greetings from NY. K8 owner also.
Offline Desert-SOHC
  • It's old
« Reply #8 on: July 08, 2017, 09:13:44 AM »
I run 100/90 on the front and a 130 on the rear.
11 Ranger S/C 2wd
Offline mt-ac
« Reply #9 on: July 19, 2017, 06:04:05 PM »
Thanks for posting about tire sizes, this is something else I definitely need to replace on my 77'.
