Author Topic: CB550 electrical issue  (Read 1134 times)
Offline mjcarley
« on: July 06, 2017, 10:28:06 AM »
So the engine is back in the frame and wired. I want to check the electrics before I try running it with petrol in. The neutral switch needed a bit of adjustment but the lights now come on.
The issue is that the indicators do not flash, and the starter motor does not turn when I hit the switch, though I can hear the solenoid click. Does this sound like a dubious earth? How can I check? I would rather have the electrical circuits working before I try starting the engine with fuel in it.
Offline Bankerdanny
  • Endeavor to persevere
Re: CB550 electrical issue
« Reply #1 on: July 06, 2017, 10:34:22 AM »
lack of flashing signals and solenoid click but no starter spin are the basic signs of an undercharged battery. Do you have a multimeter? What is the voltage at the battery terminals? it should be in the 12.4-12.7 range.
Offline mjcarley
« Reply #2 on: July 06, 2017, 10:35:17 AM »
Brand new battery and fully charged.
« Reply #3 on: July 06, 2017, 11:00:29 AM »
Not only should you measure the battery with a voltmeter, you should note the voltage when you hear the solenoid click.
Did you remember to put the battery Neg cable between the motor case and the free-of-paint frame?
Offline mjcarley
« Reply #4 on: July 06, 2017, 11:13:31 AM »
I knew it was fully charged because I had measured the voltage: 12.57V. Drops to 12.2V with the starter switch on.
The starter is not turning when I short the solenoid, so that is a clue.
« Reply #5 on: July 06, 2017, 11:21:07 AM »
I don't think that is enough voltage drop for a starter carrying current.  They can draw up 100-150 amps when energized and much more when stalled (rotation prevented).  Even a good battery will drop more voltage than what you reported, with a stalled starter motor.
Check connections, apply battery power to starter cable.  Make sure the engine case has a good solid connection to the Battery Neg terminal.
