Author Topic: The Lost Socket Garage  (Read 64546 times)
Offline Scott S
Re: The Lost Socket Garage
« Reply #100 on: October 11, 2017, 03:43:39 AM »
 Oh yeah... I also installed a used, $12 relay from a GL1000 into the VF500. Rerouted the fuel lines back to stock and now the fuel pump works as it should!
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Scott S
« Reply #101 on: October 12, 2017, 03:21:02 AM »
Forks disassembled and cleaned. Ready for new seals today. I'll probably wait to add the oil until just before I slip them into the triple tree. This style uses the fork bolt to attach to the triple tree and I don't want to spill any (more) oil.
 It also took me a while to figure out how to get them apart and what, exactly, holds the seal  in place. My manual and everything I found online mentions a circlip. This "screw together" style doesn't use one.
 As far as I can tell, the oil seal is seated in here and there's a washer and then the external spring pressure holds it in place.
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #102 on: October 12, 2017, 03:26:14 AM »
Oh, and I cleaned up the wheels the best I could, tightened the spokes and dropped them and the tires off for mounting/balancing. When I went to pick them up, I was informed that I had a 17" rear wheel and not the correct 18" wheel.
 The P.O. told me that it was replaced eons ago when the cush drive failed and they couldn't find parts, so they swapped out the wheel. I actually have the 18" wheel and took a look at it before cleaning up the wheels, but it's pretty damaged inside and on the brake backing plate; like something came apart and banged around in there or someone went crazy with a hammer and a punch. So I cleaned up the one that was on the bike. Not once did I ever think to check to see if it was a different size!
 The shop ordered me a Pirelli rear tire in 2.75-17, since Michelin doesn't make anything in that size that isn't a dual sport or offroad style. Should have the wheels and tires back by Friday. Now I need to go count the teeth on the sprocket and see what it came off of, too!
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #103 on: October 13, 2017, 04:04:33 AM »
 The plan has always been to NOT restore this bike, but preserve it. I want it to look like I pulled it out of my granddad's shed and put it back on the road.
 I'd previously cleaned up the frame and sprayed it with rust converter. Yesterday, I went over it quickly with some 1500 grit, followed by 2000 grit. That was AFTER using lacquer thinner to get off the silver overspray from the fenders.
 Then I clear coated it and the tank.
 The fenders looked particularly bad. I just couldn't stand it. Cracking, peeling spray bomb paint with runs, etc. Cleaned them up and sanded them down...
 ....used up the half a can of high build primer I had leftover...
 ...and sprayed with DupliColor wheel paint in silver, followed by clear coat.
 I'm really happy with the way it all turned out. It's still a 20-footer, but looks way better than before while still retaining the "barn find" look.
 I had every bit of this material in my shop. Didn't cost me a thing, except for some time and some elbow grease. I have new tank badges and petcock for the tank to be installed later.
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #104 on: October 13, 2017, 04:08:02 AM »
 Got the fork seals installed and new rubber fork gaitors. I'll wait to add oil since the top bolt passes through the upper triple tree on this model.
 I even save the 1973-1974 South Carolina inspection sticker and cleared over the fork lowers. That was probably the last time this bike was on the road.
'71 CB500 K0
'81 Yamaha XS650
« Reply #105 on: October 13, 2017, 06:34:55 AM »
That's a great touch preserving the inspection/license tag on the fork leg.  This is coming together way "mintier" than a preservation.
Offline Scott S
« Reply #106 on: October 18, 2017, 06:57:35 AM »
 Got the S90 up on the lift. From the rear shocks forward, it's mostly done. Got all the bulbs changed, forks, front end, steering stem bearings, cables, brakes, etc., all wrapped up.
 Got the engine in and the carb on. Exhaust will probably go on later today after I clean it up some more.
 I'm waiting on some rubber bits and i need to put the new petcock on the tank.
 Out back, I need a washer/spacer for the luggage rack/shocks. Not a biggie; about five minutes work. But that 17" rear wheel....  >:(
 I swear, I don't see how that ever had that wheel working on this bike. There's evidence that  the sprocket was hitting the chain guard. Even adding a couple of thick washers, there's still slack between the swing arm and the cush drive doesn't seat properly.
 And did I mention that the sprocket itself is bent? It wobbles like a wheel that needs truing.
 I found a good used rear wheel and it's on the way. I'll keep picking at the little things until it shows up.
'71 CB500 K0
'81 Yamaha XS650
Offline Fezzler
« Reply #107 on: October 18, 2017, 08:12:37 PM »
Cool project!  Your unsurpassed stick-to-it-ness will prevail.
1975 Honda CB550f in parts in progress
1978 Honda CB550 Four K4
1971 Honda CB500 Four K0
2008 105th Anniversary Edition HD Road King
(Sold) 1998 Honda Shadow ACE Deluxe VT750
1973 Schwinn Stingray (Blue Deluxe - RIP Jack and Rose)
Offline Scott S
« Reply #108 on: October 23, 2017, 07:01:14 AM »
 Rough as a cob, but for $40, I couldn't resist. I have plans.....
'71 CB500 K0
'81 Yamaha XS650
Offline flatlander
« Reply #109 on: October 23, 2017, 07:18:12 AM »
cool! a neighbour of mine has one of these, in orange (and a bit less beaten up). my girlfriend calls it his clown bike  ;D
Offline Scott S
« Reply #110 on: October 23, 2017, 07:35:19 AM »
 I see USD forks, extended swing arm, 12" wheels and 160cc in it's future.
'71 CB500 K0
'81 Yamaha XS650
« Reply #111 on: October 23, 2017, 08:56:29 AM »
Those little Trail 70 bikes are good fun.  That seat is ready for upholstery!
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #112 on: October 23, 2017, 09:31:01 AM »
The little Honda's are great. The Trail 70 has potential. They run forever.
Not the same thing but I have a 2009 Ruckus which is a wonderful little machine. It tops out at 45mph with the tach saying about 10,000 rpm. It just hums along, no fuss, little noise. Water cooled. It will last forever.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline Scott S
« Reply #113 on: October 23, 2017, 10:14:15 AM »
 That seat is ready for the trash pile!
 All I really want is the frame and some random hardware. The engine is stuck tight and missing parts. As are the wheels/brakes.
 But I've spent more money on wings and beer before, so it'll be fun.
'71 CB500 K0
'81 Yamaha XS650
« Reply #114 on: October 23, 2017, 12:12:43 PM »
My buddy built one with his daughter that was actually displayed at the One Show a couple of years back.  I road it on his mini-flat track.  Not much in the way of suspension and I managed to burn the bejeezus out of leg as there was no exhaust shield no his new pipe (okay for street, but not for sliding it around dirt!), but it was a ton of fun.
Offline Fezzler
« Reply #115 on: October 23, 2017, 06:09:06 PM »
No fear!
Offline Fezzler
« Reply #116 on: October 23, 2017, 06:11:06 PM »
Get off the 'shine and get thee to Betty Ford!  :o
Offline Scott S
« Reply #117 on: October 28, 2017, 03:49:47 AM »
 Stripped down the CT70 yesterday. There's ALWAYS a rat's nest inside old bikes somewhere. And I probably got 5 lbs. of loose rust and dirt out of it.
 It's really not as rough as it looks. Pretty solid. I ended up with a few usable parts from the carcass, but most of it's going to be replaced with aftermarket stuff anyway.
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #118 on: October 28, 2017, 05:15:27 AM »
 It will be. It's mostly surface rust. And I'm not worried about saving the decals.
'71 CB500 K0
'81 Yamaha XS650
Offline tweakin
  • tear down
« Reply #119 on: October 28, 2017, 06:18:27 AM »
Sweet!  I have a small stable of rebuilt, "overbuilt" :) ct 70's.  Most recent is a 108 stroker on 12 inch wheels that will do 70mph.  New decals and almost any other part you need is readily available.
Offline b52bombardier1
« Reply #120 on: October 28, 2017, 08:20:03 AM »
Save that CT70 seat pan if at all possible. Those Thailand replacement pans are not as good as the original pans from Honda. Thinner metal and less precise fitment.
Rick
Sent from my SAMSUNG-SM-N900A using Tapatalk
1971 School Bus Yellow Aermacchi H-D Sprint 350
1972 Candy Yellow CL100 K2
1972 Candy Jet Green Honda CB500
1973 Mighty Green ST90 K0
1974 Mars Orange CT90 K5
1975 Topaz Orange ST90 K2
1976 Shiny Orange CT90
2006 Honda Foreman 500 (restored)
Offline Scott S
« Reply #121 on: October 28, 2017, 08:42:55 AM »
 What sprocket combo are you using? I'm set on the Piranha 140 and 12" wheels.
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #122 on: October 28, 2017, 08:43:46 AM »
Rick
 I haven't thrown away anything yet, but man is it rough....
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #123 on: October 28, 2017, 09:01:44 AM »
 Got the last few tiny bits in and have the S90 about 99% done.
 I had to order a replacement rear wheel in the correct 18" size. I'll kiss your butt if they ever had that 17" wheel on there correctly. The axle wouldn't tighten up properly, and there was evidence that hard parts had been touching hard parts. Even the sprocket was wavy!
 I just need to charge the new battery and repair a couple of wires where, once again, someone had done a crappy job with the old battery. Then I'll be ready to hear it (hopefully) run for the first time since '73-74!
« Last Edit: October 28, 2017, 11:25:32 AM by Scott S »
'71 CB500 K0
'81 Yamaha XS650
Offline Fezzler
« Reply #124 on: October 28, 2017, 12:33:25 PM »
Rick
Which is rough?  The seat or throwing things away?   ;)
