Author Topic: The Lost Socket Garage  (Read 105226 times)
Offline flatlander
Re: The Lost Socket Garage
« Reply #175 on: March 04, 2018, 08:24:16 AM »
they both look great. i'm sure you'll have lots of fun with them!
Offline Scott S
« Reply #176 on: March 08, 2018, 01:04:26 PM »
Slow going on this one, but getting some research done and making baby steps.
 Rick at OldSkoolCarbs took care of the  '95 GSX-F carbs for me. He found a few bent and rotten choke parts and will also assist with jetting for the pods when the time comes (this build, with the GS550 frame, doesn't allow for the stock air box and these carbs are supposed to play better with pods than the '00 models). I plan on using the K&N dual intake filters. I believe that RU-2922 is the part I need.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Scott S
« Reply #177 on: March 08, 2018, 01:13:03 PM »
 Also figured out the front end/triple tree. The 1980 GS550 used tapered bearings and the 2000 GSX-F uses caged bearings. I used the GSX 750 lower triple, a top triple from a same year 600, and bar risers from a Bandit 600. My Dad did a little grinding and modifying, and I ordered new tapered bearings from AllBalls, and now I have a '00 front end, forks, wheel and brakes on an '80 GS550 and still retain the handlebars. Ignore the tall bars....they're just for mock up and pushing it around the garage.
 Next up is to rebuild the forks and brakes and do a little detailing. We also have a pretty good plan on getting the Katana swingarm to fit.
'71 CB500 K0
'81 Yamaha XS650
Offline DurangoCB
« Reply #178 on: March 08, 2018, 01:19:56 PM »
I can't decide which bike I like more, the CT or the CB.  Nice work.
It's unbelievable what OldSkool can do with carbs.  They look photoshopped (I know they're not).  Amazing.
The GS didn't come stock with those top clamps, did it?  If not, who did you buy those from?
1971 CB500 Four- current project http://forums.sohc4.net/index.php/topic,170622.0.html
1978 CX500- next in line
Offline Scott S
« Reply #179 on: March 08, 2018, 01:27:25 PM »
 No, that's a Katana 750 bottom triple and a Katana 600 top triple. We drilled it for risers, since they both come with clip-on bar's. The risers are for a Bandit 600.
 This allows me to run 41mm forks vs. the stock 35mm, as well as dual floating, drilled rotors and twin dual piston calipers. And the much lighter 17" Katana wheel. The forks are also adjustable.
 It'll look "stock" from 30 feet away, but be much more modern and beefier.
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #180 on: March 26, 2018, 11:42:10 AM »
 I was leaning towards keeping the outward appearance on the GS550/750 "old school", but I found this Yoshimura slip on and was able to get it for $130 to my door. It's a $400 pipe and the dyno graphs show (presumably) big increases over stock. I figured that, along with the pods, jetting and some dyno tuning and I ought to be able to get to 100HP vs. the 94HP Suzuki claimed. And it would probably be easier to tune for this pipe vs. some cobbled together system.
 No matter, it ought to be a good bit more than the 49HP that the GS550 was rated!
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #181 on: March 26, 2018, 11:42:54 AM »
 I also found clevis mounts to convert from mono shock to dual. Hope to get the swing arm fitted next week.
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
'71 CB500 K0
'81 Yamaha XS650
Offline flatlander
« Reply #183 on: April 04, 2018, 07:48:06 AM »
the first one sounds vaguely familiar  ;D
but what about that clown bike, would that not scare the kids in the circus??
Offline Scott S
« Reply #184 on: April 04, 2018, 07:57:10 AM »
 It scares the crap outta me!! 44.25" wheelbase, 12" wheels/tires and geared for ~62 MPH.
 And, honestly, the Passolini pipes on the CB sound better in the video than in my helmet. They're LOUD when I'm on the bike but sound much better as an observer, IMO.
« Last Edit: April 04, 2018, 08:26:44 AM by Scott S »
'71 CB500 K0
'81 Yamaha XS650
« Reply #185 on: April 04, 2018, 08:11:04 AM »
 It scares the crap outta me!! 44.25" wheelbase, 12" whee;s/tires and geared for ~62 MPH.
Those pipes sound fantastic!
Your CT reminds me of a Honda Grom fitted with a modern CB300 single!
Offline flatlander
« Reply #186 on: April 04, 2018, 08:13:43 AM »
the CT is fun, though. over here they were called "dax" for some reason.
i have the same with the pipes, very loud in the helmet even with ear plugs especially when spending more time at high speed on the highway. i might try a lollypop at some point to see if it dampens the sound a little, for longer trips.
but as you say, they do sound very good from a spectator point or view.
Offline Fezzler
« Reply #187 on: April 04, 2018, 11:15:13 AM »
[/quote]
[/quote]
The day I heard them when following on my cb550 they really did sound awesome.  Very impressive.
1975 Honda CB550f in parts in progress
1978 Honda CB550 Four K4
1971 Honda CB500 Four K0
2008 105th Anniversary Edition HD Road King
(Sold) 1998 Honda Shadow ACE Deluxe VT750
1973 Schwinn Stingray (Blue Deluxe - RIP Jack and Rose)
Offline Scott S
« Reply #188 on: April 06, 2018, 03:55:32 PM »
Took a band saw and a belt grinder to the Katana swing arm...
...did a whole bunch of measuring to find the center...
 ...and then a whole bunch MORE measuring to center it in the frame. Here, my Pop is mocking up the shocks and getting the angle correct so that we can get the lower clevis mounts welded on.
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #189 on: April 07, 2018, 03:49:24 PM »
 For some reason, when I tried to stabilize the video YouTube loses over 30 seconds of it. Here it is in it's (shaky) entirety.
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #190 on: May 31, 2018, 01:03:14 PM »
So, this happened....
 Found a local guy that's an engineer and has some gab skills. He's doing all of this from his home garage. I couldn't be happier. He truly "gets" what I'm trying to accomplish and is doing quick, neat work. Today was just a "touch base and check on progress" kind of day and I'm thrilled.
 The rear upper mount is very nice and it, along with the lower RH mount, will be removable and make getting the engine in and out very easy.
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #191 on: May 31, 2018, 01:06:13 PM »
The front mounts are the stock Katana mounts that he cut/modified and welded. The rubber dampener inserts were rather worn, so he made these aluminum spacers.
 He wasn't quite happy with that though, so he made theses Delrin spacers.
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #192 on: May 31, 2018, 01:11:44 PM »
 I think it's gonna look really cool...and function great, too. He's still working on two of the lower middle engine mounts. We also checked header fitment and discussed the oil cooler mounting today.
 He's already checked chain alignment with a straight edge. Today, we ran the chain across the sprockets (I'm gonna need a longer chain) and it clears the frame, but is tight. The upper run can probably be cured with an acetylene torch and a ball peen hammer. The lower run may require some minor clearancing around the foot peg mount bosses. Switching to a 520 chain really helped.
 I'm also going to take the muffler with me next time I go and discuss a rear hanger for it.
 Oh, and he's going to work on the steering stop to prevent the larger forks from hitting the tank.
'71 CB500 K0
'81 Yamaha XS650
« Reply #193 on: May 31, 2018, 01:54:49 PM »
Those are some meats (tires)!
Offline Scott S
« Reply #194 on: June 26, 2018, 10:25:15 AM »
 Picked up this neat little 1972 CL175 a few weeks ago. Found a nice stock exhaust for it and got it on today.
 Here's a thread I did on it (don't know why I didn't add it here):
http://forums.sohc4.net/index.php/topic,172385.0.html
'71 CB500 K0
'81 Yamaha XS650
Offline MoMo
  • Ride like you're invisible
« Reply #195 on: June 26, 2018, 11:13:25 AM »
Looking real good Scott ;D
« Reply #196 on: June 26, 2018, 01:11:49 PM »
You know what KYB stands for?
Keep your Bilsteins.
Catching up on the thread, was not aware how much I had missed.
David
Picked these up, too. I guess I made a decision on dual shocks vs. mono shock!  ;D
« Reply #197 on: June 27, 2018, 09:22:12 AM »
Following  :)
Offline Scott S
« Reply #198 on: June 28, 2018, 09:49:27 AM »
Adventuring further and further from home on the CT70. This thing doesn't have an odometer or speedometer, and it's still a fresh-ish build, so I'm still a little skittish about getting farther away from home than I want to push it!
 Rode around the back roads near my house for twenty minutes or so. I swear, it needs a 5th gear. Or different sprocket ratios. It's pulling HARD and going plenty, plenty fast and still feels like it has more in it.
 I need to find a GPS speedo app for my phone and hook up my RAM mount.
'71 CB500 K0
'81 Yamaha XS650
Offline MoMo
« Reply #199 on: June 28, 2018, 08:43:29 PM »
Scott, use the app Waze as it has a great GPS that also gives MPH...Larry
