Author Topic: 77 750F Charging?  (Read 3077 times)
Offline reliv77
77 750F Charging?
« on: July 15, 2017, 01:01:19 PM »
How do I check if system is charging or not?
Offline chuter1
Re: 77 750F Charging?
« Reply #1 on: July 15, 2017, 01:29:48 PM »
Very simple,  Connect a VOM to the battery, set at 20vdc. Start the bike and read the voltage.  If around 12.5 to 13.5 vdc it should be ok. There is more to this procedure but this will get you headed in the right direction.  Check it out and let us know.  Al
Offline reliv77
« Reply #2 on: July 15, 2017, 01:49:37 PM »
Thanks for the reply. Bit of a novice here. My meter has DCV not VCD. Same thing?
Offline reliv77
« Reply #3 on: July 15, 2017, 02:56:39 PM »
Not good?
Offline reliv77
« Reply #4 on: July 15, 2017, 04:41:57 PM »
Al....This look right to test?
Offline chuter1
« Reply #5 on: July 15, 2017, 04:46:08 PM »
VDC =  volts  direct current.  That is what you want. I'm sorry if I typed VCD.  Anyhow,   what you want to read is about 12.5 to 13.5.  Anything less and you have a problem.  Now finding that problem is a different matter altogether.  Al
Offline chuter1
« Reply #6 on: July 15, 2017, 04:50:37 PM »
I am reading it as 12 VDC.   Shut the bike off and then read the battery voltage again...  Are you having some specific problem or what.  Al
Offline reliv77
« Reply #7 on: July 15, 2017, 06:50:11 PM »
It started out that my turn signals started acting slow (lights and sound) then had a real hard turn over electric start that did not start the bike. Kick started it to get home.
Offline calj737
  • I refuse...
« Reply #8 on: July 16, 2017, 04:34:33 AM »
Then you have a depleted battery at this point. Properly recharge your battery with a quality charger. Remove from the charger, then test the battery again with the meter, probes directly on the battery terminals.
What voltage do you read exactly? "12 volts" as a reading/measurement is not specific enough.
Your battery must be good, verified healthy before you diagnose any charging issues elsewhere on your bike.
Offline b52bombardier1
« Reply #9 on: July 16, 2017, 05:01:33 AM »
Another aspect here is how well is your rectifier filtering out AC to prevent the AC from damaging your battery.  Your analog meter above might not be the best for seeing this type of measurement. And the inexpensive Harbor Freight multimeters are not the best for it either.  I use a Fluke 17B multimeter which is overkill but something in the 25-30 dollar range might be OK.  Ask around and borrow one before buying a good meter.
   You almost can't work on these bikes without a modern digital multimeter.
Rick
1971 School Bus Yellow Aermacchi H-D Sprint 350
1972 Candy Yellow CL100 K2
1972 Candy Jet Green Honda CB500
1973 Mighty Green ST90 K0
1974 Mars Orange CT90 K5
1975 Topaz Orange ST90 K2
1976 Shiny Orange CT90
2006 Honda Foreman 500 (restored)
Offline reliv77
« Reply #10 on: July 16, 2017, 08:33:42 AM »
Slow charged the battery all night.
Took the battery to local Auto Store.
Battery tested Good.
Had all this done just last year by a Certified Honda Motorcycle Mechanic...( see attachment)
Had a similar problem after that.
Dim headlight, slow turn signals and then a totally dead bike.
Removed the Fuse Panel and blasted it.
After that Head Light was Bright, Signals worked great and it fired right up.
Input would be appreciated.
Offline calj737
  • I refuse...
« Reply #11 on: July 16, 2017, 11:37:05 AM »
"Tested good" means little to nothing. Use a meter and post the actual measured value. Otherwise it's any 1 of 1,000 things, most of which require actual data, not "did this in the past" references.
Offline reliv77
« Reply #12 on: July 16, 2017, 03:11:03 PM »
The Auto parts guy tested the battery in the back of the store.
All he told me was that it tested "Good".
No idea what the reading was.
Offline calj737
  • I refuse...
« Reply #13 on: July 16, 2017, 04:48:24 PM »
Should have grabbed a meter while you were there.
Offline reliv77
« Reply #14 on: July 17, 2017, 07:54:00 AM »
Volt Meter
Offline calj737
  • I refuse...
« Reply #15 on: July 17, 2017, 08:24:00 AM »
Offline reliv77
« Reply #16 on: July 17, 2017, 08:32:15 AM »
Multi Meter
Offline calj737
  • I refuse...
« Reply #17 on: July 17, 2017, 09:13:28 AM »
Now test your battery with it and post the actual values read.
Offline reliv77
« Reply #18 on: July 17, 2017, 09:24:18 AM »
Its showing the read....isn't it?
Offline calj737
  • I refuse...
« Reply #19 on: July 17, 2017, 09:33:38 AM »
Sorry, is that picture of the actual battery voltage? If so, your battery looks to be toast.
Offline reliv77
« Reply #20 on: July 17, 2017, 10:51:07 AM »
That is Multimeter to battery posts while bike was running.
Offline calj737
  • I refuse...
« Reply #21 on: July 17, 2017, 12:12:24 PM »
Take that reading with bike OFF too please.
Offline reliv77
« Reply #22 on: July 17, 2017, 06:07:28 PM »
A experianced (Motorcycle) friend stopped over with a decent Voltage Meter. He frowned upon my Radio Shack MultiMeter.
Electrical System (charging) is working fine.
His guess is that somewhere a possible wire / short depleted the battery and may only occur perioadicaly.
His suggestion is to look for a decent wiring harness to replace the existing one.
Offline Spanner 1
« Reply #23 on: July 17, 2017, 10:50:10 PM »
Did your experienced friend do the very-first-thing to check with charging problems on these bikes ?... that is to undo the 8-way plug under the left hand side cover and examine the male pins for overheating/ burning and melting of the connector  and resultant  iffy/no connection of the alternator  ( yellow-yellow-yellow ) wires or the field coil wires ( white and green ) ?? When a meter connected across the battery wont read at least 13.5v @ 5,000 rpm then go straight to that connector ;)
« Last Edit: July 17, 2017, 10:53:23 PM by Spanner 1 »
Offline reliv77
« Reply #24 on: July 18, 2017, 04:58:05 AM »
No we did not do any further than checking if the bike was charging.
Need to move on with your advise.
Thanks.
