Author Topic: gasket material that will withstand ethanol gas  (Read 1036 times)
Offline eigenvector
« on: July 19, 2017, 12:49:56 PM »
I need to seal a mating surface that will come into contact with gas, but so far I'm not finding anything that will tolerate gasoline or alcohol.
It's a fuel tube, so it needs to be a paste that I can press or rub into position - otherwise I would just use neoprene sheet or the like.
Do you know if Permatex Ultra-Copper or Blue will withstand fuels?  Permatex says "not recommended", but in this instance it doesn't have to withstand pressure - just fill a small void.
Gasoline and Ethanol are unfortunately simply too good of solvents for their own good sometimes. >:(
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
Offline Jmed22
Re: gasket material that will withstand ethanol gas
« Reply #1 on: July 19, 2017, 01:12:00 PM »
Seal-all works good for gas and oil but stays kind of like rubber cement. It definitely works on areas where gas comes in contact and won't degrade from it
Sent from my Life One X2 using Tapatalk
Offline Jmed22
« Reply #2 on: July 19, 2017, 01:21:15 PM »
This is the stuff. I have used it in the past and has worked great. Also its like $5
Offline eigenvector
« Reply #3 on: July 19, 2017, 01:45:16 PM »
Thanks, I'll take a look at it.
Rob
1977 CB550K
1983 VF750S Sabre
Offline Steve F
« Reply #4 on: July 19, 2017, 03:53:31 PM »
What exactly are you trying to fix??
Offline Jmed22
« Reply #5 on: July 19, 2017, 03:56:18 PM »
No problem it will work just fine. And is not very expensive
Offline Deerslayer
« Reply #6 on: July 20, 2017, 05:11:32 AM »
Bob
Offline Jmed22
« Reply #7 on: July 21, 2017, 06:55:11 AM »
Wasn't sure if you happened to get some of that seal-all and give it a try yet?? I honestly think it will be perfect for what you need and like I mentioned I have used in the past with great results
« Last Edit: July 21, 2017, 01:35:55 PM by Jmed22 »
Offline eigenvector
« Reply #8 on: July 21, 2017, 08:50:49 PM »
I did, thank you again.
Rob
1977 CB550K
1983 VF750S Sabre
Offline Jmed22
« Reply #9 on: July 22, 2017, 05:18:25 PM »
Nice so it must be it worked? Glad I could help if it did work for you. Anytime that's what we are all here for.
