Author Topic: Sprocket nuts hitting lower shock nuts after rear brake changed out  (Read 4133 times)
Offline CycleRanger
  • No comment about being an
Re: Sprocket nuts hitting lower shock nuts after rear brake changed out
« Reply #25 on: July 22, 2017, 10:50:00 AM »
Also why is there two different schematics for the rear wheel?
The one I posted is from the parts list. The other is from the manual.
Offline gbal06
« Reply #26 on: July 22, 2017, 10:59:51 AM »
gotcha thanks
Offline Airborne 82nd
« Reply #27 on: July 22, 2017, 11:49:22 AM »
I agree, I am going to take it back apart tomorrow and look at everything.  Can someone tell me which way #17 goes on?  is it the big side toward the wheel or the small size (that slides in to the wheel)  Thanks
17 is the inner tube goes inside the tire ;D
« Reply #28 on: July 22, 2017, 11:56:51 AM »
There may be 500 and 550 versions.
Offline gbal06
« Reply #29 on: July 22, 2017, 12:31:15 PM »
so for the 550k version which way should it go?  Currently the smaller side is going towards the wheel.
Offline innovativems
    • Innovative MotoSports
« Reply #30 on: July 22, 2017, 12:34:20 PM »
Like cal said
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
Offline gbal06
« Reply #31 on: July 22, 2017, 12:50:03 PM »
Like cal said
ok tomorrow I will take the wheel off and switch the collar to larger toward the wheel to see if that changes the spacing
Offline gbal06
« Reply #32 on: July 22, 2017, 02:51:08 PM »
Here is what the spacing looks like with the current collar
« Reply #33 on: July 22, 2017, 03:26:10 PM »
Is that a nylon on the shockbolt, if so remove the washer behind it.
Offline gbal06
« Reply #34 on: July 22, 2017, 03:55:45 PM »
I don't believe it is but I am at work and will take a look at it tomorrow
« Reply #35 on: July 23, 2017, 12:44:58 PM »
In his first linked picture, it's the collar. Fat end towards wheel-
Don't see why or how there are two different pic for same year and model something is not correct I thought cmsl uses the manual for there site pic. I think we are looking at two different bikes or models.
cal that was my poor attempt at humor
Offline CycleRanger
« Reply #36 on: July 23, 2017, 02:06:00 PM »
The diagrams are the same only the part numbering is different.
« Reply #37 on: July 23, 2017, 02:29:53 PM »
I think you mean  the part illustration numbers are different .
