Author Topic: Going low to high...  (Read 1193 times)
Offline Dirty Steve
« on: July 21, 2017, 08:00:39 PM »
Hello all,
I'm looking at riding my bike up to Colorado from Austin, Texas, and will be passing over a few 10,000 foot peaks but most of my riding, once I get there, will be closer to 6,000-7,000 foot range.
Right now I run 110 mains, 40 pilots and the jet needle on the middle clip.
My question is, will it be necessary to stop and re-jet before I get to the Rockies, or is there some combination-say, going down to a 103 main-that will work well enough in both Texas and Colorado?
Thanks,
Dirty Steve.
P.S. It's a completely stock CB750K5.
« Last Edit: July 21, 2017, 09:02:04 PM by Dirty Steve »
Riding motorcycles will make you a poet. Working on them will make you a philosopher.
1975 CB750K5 with stock airbox, exhaust et al...
Offline tlbranth
Re: Going low to high...
« Reply #1 on: July 21, 2017, 08:05:16 PM »
My K0 has been over the Sierras and Rockies numerous times in the last 47 years and had no problem with stock setup. Unless you're close to wide open, main jet doesn't have much effect anyway.
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline Dirty Steve
« Reply #2 on: July 21, 2017, 09:03:06 PM »
Thanks for your reply.
What size jets and which needle clip do you use?
« Reply #3 on: July 21, 2017, 09:30:46 PM »
I recommend just one thing: when you get to high altitude, drop an octane number at the pump. If you're running premium in Texas, run mid-grade up here. The fuels available here, above 3500 feet, are altitude-blended to approximate the lower air density for EFI systems, but this doesn't drop the volatility quite enough for our carb'd bikes. Thus, for a car that runs premium in Texas, the fuel here is adjusted to give the same emissions, with less oxygen, for the EFI's programmed burn rate. This is one calculation that cannot be taken on-the-fly very well, although the mass airflow sensors come pretty close: they detect less density, but not necessarily less oxygen, so it is "after the fact" that the oxy-sensors in the exhaust try to correct it. Still, this isn't like our mechanical mixers...
As an example: I run premium (stock carb jetting) in my K2 unless I am spending lots of time in city stop-and-go traffic: then I drop to mid-grade. If I am heading for [real] high altitude (above 8000 feet) for an extended time, like an assault on Mt. Evans or Pike's Peak, I'll drop to regular grade so it won't be so doggy above 10,000 feet, which may start fouling plugs or something along those lines. But, if I am crossing the mountains at hiway speeds, even crossing the passes (most of these are 10,000 feet or less), I'll run the mid-grade instead of premium. If you have the standard engine (not the Wiseco or Powroll high-compression pistons), this will work fine.
Just bring along an extra set of plugs, in case you get it mixed up or something, and foul a plug. ;)
If you like to tweak carbs: bring along a screwdriver and when you get above 5000 feet for a week or more, turn the air screws inward about 1/16 or 1/8 turn, all 4. It will start better and idle instead of needing constant assistance to stay lit "up high' while sightseeing on the side of the road. When you get back to less than 4000 feet, turn them back out to 1 turn.
Offline Dirty Steve
« Reply #4 on: July 25, 2017, 12:08:39 PM »
Thanks Honda Man for the info on different fuel grades. That and the effect of ethanol on these old bikes is a little mystifying to me.
I want to make sure I'm getting this...
If you're in the mountains at highway speed, mid-grade works, but if you're stopping a lot low-grade is better? (This is assuming I use premium down here.)
Also, you're saying turn the idle screws inward to enrichen the mixture above 5,000 feet, not outward to lean it out?
Thanks...
« Reply #5 on: July 25, 2017, 07:06:05 PM »
Thanks...
Most likely, you'll be on the roads, sightseeing, and not struggling with big-town traffic, so mid-grade should work out fine.
Screws: inward leans it out. Despite what the internet says about it. Try it when you get here, you'll see. ;)
