Author Topic: 2 Stroke help  (Read 1619 times)
Offline tylerdb
2 Stroke help
« on: July 23, 2017, 06:17:14 PM »
Found a crack in my cylinder wall by the exhaust port, looks like spider webs. Is getting the cylinder replated the best option? Think I could get away with just a piston and rings for the next few months so I can replate this winter?
Saskatchewan, Canada
Offline MoMo
  • Ride like you're invisible
Re: 2 Stroke help
« Reply #1 on: July 23, 2017, 08:18:17 PM »
single, twin or triple?   Replating?  not too many 2 strokes had plated cylinders( IIRC Bridgestone was one).  You could get by but since it is apart, do it right.  Some bikes had replaceable cylinder liners...Larry
Online jgger
Re: 2 Stroke help
« Reply #2 on: July 23, 2017, 09:39:02 PM »
Looks like a sleeve. If it is plated the barrel looks to be pretty damaged. 2 Strokes are harder to sleeve because you need to match up all the ports, might be cheaper to find another cylinder unless they are made out of unobtainium.
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=nrlpgl3h00v8eihcmjr2ao4l30&/topic,60973.0.html
Re: 2 Stroke help
« Reply #3 on: July 24, 2017, 05:01:23 AM »
the hard crome is peling off...so a dead end..get a new cylender if it are a common modell..or get it bored aut re hard cromed use the nicrasil type..id it are one of its kind engine..
i hate all this v-w.... vords
Re: 2 Stroke help
« Reply #4 on: July 24, 2017, 06:35:02 AM »
+1...new cylinder is what I would do.  What bike?!
Offline tylerdb
Re: 2 Stroke help
« Reply #5 on: July 24, 2017, 06:44:16 AM »
Bike is a Suzuki RM250 was hoping I could get it replated or sleeved at least
Offline tylerdb
Re: 2 Stroke help
« Reply #6 on: July 24, 2017, 06:44:27 AM »
Offline strynboen
Re: 2 Stroke help
« Reply #7 on: July 24, 2017, 10:08:14 AM »
you can..but to machine the cracked hardcrome aut is a problem..is there aftermarked pistons to get??is it a motocross ..had a rm 125 back in time..a 1979 aircooled.
.can some dt-250 Yamaha parts make  fit to it..they are less costy like a dt lc.. year 82vitaut the valve kontroled exhosts port..
Offline simon#42
  • liverpool
Re: 2 Stroke help
« Reply #8 on: July 24, 2017, 10:34:53 AM »
just wants a small weld and a re plate , i have repaired much worse than that one .
would not use it as is though you will just ruin the new piston and ring , it wont be hard crome it will be nicasil . i dont know where you are in the world but here in england
it would cost about 140 quid to repair and plate it .
