Author Topic: New "replica" cam chain tensioner for CB550  (Read 3272 times)
Offline jamesk
« on: July 29, 2017, 11:19:31 am »
Well my 77 CB550 has a mangled tooth on the cam chain tensioner.  I removed it and it doesn't really look repairable even though the rest of the thing is in good condition with very little wear.  The only honda ones I could find (NOS) are $275 plus shipping.  There is a guy on ebay selling new "replica" units for $189 with free shipping.  Anyone used one of these replicas?  Pretty good amount of savings and I'm considering pulling the trigger on it.
http://www.ebay.com/itm/Honda-New-CB500-Cam-Chain-Tensioner-500-550-CB550F-CB550K-CB500K-14500-323-000-/321673401017?hash=item4ae53a92b9:g:xp4AAOSwEeFU5QBo&vxp=mtr
Re: New "replica" cam chain tensioner for CB550
« Reply #1 on: July 29, 2017, 11:36:37 am »
Unfortunately, you dont have much choice.
Offline uksparky
  • Track days
« Reply #2 on: July 29, 2017, 12:42:17 pm »
I just checked e bay used one in USA for $10..you can get the part the chain rides for less than $50
Present bike 1982 900C Custom
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=hri1aucu5a7s8c3b2q7gv1dlq0&/topic,60973.0.html
« Reply #3 on: July 29, 2017, 01:34:30 pm »
try to bay a old veared tensioner..and build a good one aut of it...somone here on forum..must have one.(.ve dont just dump old parts aut..)save them at the attic...for nostalgic...that can make your day...happy...
i hate all this v-w.... vords
Offline Scrambled
« Reply #4 on: July 30, 2017, 09:20:01 am »
Not that i can offer any help on this but my cam chain tension adjustment is stuck, the little rod that comes out the middle of it with a slot screw driver notch has broken off. So I cannot loosen the automatic adjustment locking nut. When you find a good solution for a new cam chain tensioner if you could post it that would be amazing!
Offline drumstyx
« Reply #5 on: July 30, 2017, 09:25:41 am »
Have you checked CMSNL for an OEM one?
Offline jamesk
« Reply #6 on: July 31, 2017, 08:47:45 am »
Ouch!  That's a bummer.  You could try to cut a new slot in the threaded shaft but you'll need to get the nut free first.  Try some kroil overnight.  If you torqued on it enough to break the slot on the end, you may have borked the gear teeth on the inside which would require a full teardown of the top end (jugs have to some off to get the tensioner out).  When you get the nut free, check for free movement of the threaded shaft.  It should want to spring back in the clockwise direction when you turn it anti-clockwise.  If it doesn't, it's borked.  Good luck!
Offline Deltarider
  • First round...
« Reply #7 on: July 31, 2017, 08:54:00 am »
Where did you learn that?! It's the other way around actually.
CB500K2-ED Excel black
Offline CBGhia
« Reply #8 on: July 31, 2017, 08:56:07 am »
I just looked and even the used ones are going for stupid money.
I have a good one that came out of my 550 engine.  I even have a new slipper that was never installed.
I'll let it go for a lot less than than they seem to be asking on eBay.
If you are interested, send me a PM.
Offline strynboen
« Reply #9 on: July 31, 2017, 11:53:32 am »
is anybodu build a adjustabel from autside like the 750 type..like to have a adjuster plastic handel stikking aut of the engine..and a sekure contra bolt to Lock it..so ve just schrev inn to teighten and Lock it vhen it feel right..and forget that krazy spring system
Offline kmb69
« Reply #10 on: July 31, 2017, 12:55:00 pm »
You can bet if JT is selling the replicas for $189.00, they are probably half that price from his source.  ;)  Just have to find out where he's getting them from.  ???
Offline Deltarider
  • First round...
« Reply #11 on: July 31, 2017, 01:44:58 pm »
+1, that would be great.
Offline Smudgemo
  • Maker of Stuff
« Reply #12 on: July 31, 2017, 02:02:29 pm »
I haven't gotten the top off my engine yet, but it's just a matter of time based on some seeping and what I think is a rattly cam chain while cold.  I see CMSNL offers a non-OEM replacement for about $150.  Of course you can add another $20+ for shipping.  Not that it's cheap, but if it works and lasts..
https://www.cmsnl.com/honda-cb550f-super-sport-550-four-1976-usa_model467/tensioner-chain_14500323000/#.WX-ZL-mQxaQ
-Ryan
Thread - How to fix your starter button (for real): http://forums.sohc4.net/index.php/topic,163170.0.html
Offline kmb69
« Reply #13 on: July 31, 2017, 02:59:44 pm »
That's Euros. About $177.00 USD.
Offline jamesk
« Reply #15 on: July 31, 2017, 09:14:41 pm »
http://www.ebay.com/itm/1976-HONDA-CB-550-CAM-CHAIN-TENSIONERS-/292194439259?hash=item440825505b:g:-PkAAOSw6lxZdpx5&vxp=mtr
I won this auction! Depending on the condition of the slipper piece, I may move my slipper to this frame. We'll see!
Offline CBGhia
« Reply #16 on: August 01, 2017, 06:52:59 am »
Score!  You can get new slippers if you need them.  They are not much.
« Reply #17 on: August 01, 2017, 09:06:20 am »
The DSS OEM replacments is $185.  I believe they used to sell them for $200 plus (maybe they found a better source)/
https://www.davidsilverspares.com/CB550K1-1975-USA/part_176179/
