Author Topic: front end noise - Bearings? Tach? 1975 CB550  (Read 554 times)
Offline KevinD
« on: July 30, 2017, 11:01:50 AM »
I have a 1975 cb550 which has been kept up well.  The bike has about 9000 miles on it.  I noticed that my front end has been giving a noise similar to an old roller skate wheel.  I have also noticed my tachometer has been bouncing around.  I jacked up the front end and could really find no play in the front wheel and no noise when hand spinning.  The front brake is making a slight squeak but it has done that for a while.  I have already taken apart the brake and rebuilt it which temporarily fixed the squeak but it's back.  Anyway, my concern is the front end locking up if it is a bearing issue.  Any ideas would be greatly appreciated.
Thanks.
Kevin
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=dckbpptvev4or9o923e1d9f590&/topic,60973.0.html
Re: front end noise - Bearings? Tach? 1975 CB550
« Reply #1 on: July 30, 2017, 12:28:22 PM »
try to lube the bronze bearing up in the taco/spedo..mine cb 550 and my cbx did the same..and i just lubed the problem aut of this vorld
think i need to split the unit to get it real kleaned and lubed korekt..but some wd 40 did the job ..and i afterlubed vith some thikker oil..the 40 vas just to open up for the real oil..
the spedo can make a real heigh noising..dont think you have a bearing problem..but its a low cost job to thange them..
« Last Edit: July 30, 2017, 12:33:15 PM by strynboen »
i hate all this v-w.... vords
Offline KevinD
« Reply #2 on: July 30, 2017, 02:29:08 PM »
Thanks strynboen I appreciate the response.
Offline Johnie
« Reply #3 on: July 30, 2017, 02:39:10 PM »
Tach bouncing...could be the tach cable is getting ready to break.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
« Reply #4 on: July 30, 2017, 04:03:29 PM »
yep, and that can make the noise you describe too
Offline Johnie
« Reply #5 on: July 30, 2017, 06:12:19 PM »
And not a costly fix either.
Oshkosh, WI  USA
Offline tlbranth
« Reply #6 on: July 30, 2017, 06:25:09 PM »
disconnect the tach and/or speedo at the drive end and see if the noise goes away. I had needles bouncing all over the place when I first restored my 750. Put on new cables and the bouncing pretty much went away.
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
