Author Topic: Gears grind when shifting between neutral 1st and second  (Read 1025 times)
Offline Sportyspice
« on: August 04, 2017, 10:42:18 PM »
Recently revived cb750f
If I am revving the bike at all while shifting between neutral first or second there is a pretty hideous gear grinding and it won't shift into gear.  If I don't rev the bike at all the bike shifts fine.  Any ideas as to why  would be greatly appreciated.
Re: Gears grind when shifting between neutral 1st and second
« Reply #1 on: August 04, 2017, 11:04:07 PM »
Dragging clutch.
« Reply #2 on: August 05, 2017, 08:19:31 AM »
get a manual and go through the clutch adjustment procedure
Offline Sportyspice
« Reply #3 on: August 05, 2017, 12:26:25 PM »
Thanks a lot for the feedback.  I have a manual and I'm struggling through the process. I love how cut and dry it sounds in the manual and how much I'm struggling with the adjustment lol.
Offline CycleRanger
  • No comment about being an
« Reply #4 on: August 05, 2017, 12:51:18 PM »
how long did it sit?
What oil did you use?
Offline Sportyspice
« Reply #5 on: August 05, 2017, 03:42:06 PM »
Sat for about 20+ years.  New oil and filter 10w-40. I just made the adjustment for the clutch and maybe a little better but by no means totally fixed.
Offline CycleRanger
« Reply #6 on: August 05, 2017, 05:05:19 PM »
Did you use 4 stroke motorcycle oil?  Motorcycle oil is formulated for wet clutches.
If it sat for 20 years the clutch plates probably stuck and may still be sticky.
It may require a bit more usage for them to completely free up.
If the issue persists you may have to pull the clutch and inspect the plates.
If you didn't use oil formulated for 4 stroke motorcycles go ahead and change it.
You're going to want to change the oil again fairly soon anyway as all the sludge that developed while bike was sitting will be circulating though the motor and will quickly accumulate in and clog the filter.
It's also not a bad idea to remove the oil pan and check the screen at the oil pump.
« Reply #7 on: August 05, 2017, 08:01:37 PM »
Shift quicker, too. Don't try to "slip" these bikes into gear: they just get confused...just pop into gear, whichever one you use  :)
