Author Topic: Rear hoop on a cb550  (Read 2746 times)
Offline work9to5
« on: August 07, 2017, 12:22:05 AM »
So I ran into something interesting today when going to put a rear hoop / loop on one of my 550's. I found the stock frame tubes extend to different lengths when I chopped the rear horns off and exposed them. Havnt seen that before. Have done one hoop job before not on a Honda. I've measured it 10 times they are in fact different lengths. Pics attached
I've got two ways I can think of to go about this but if anyone has suggestions please lmk
1.) cut the hoop un even so that one end extends farther to reach where it needs to butt up. Use a rotary tool to trim back the un even side so I can get a good weld on there.
2.) cut back the tube. Cutting open from the tops evenly. Leaving the hoop the same lengths. And then pushing the hoop slugs into the "slots" I've created so I can get an even weld on both.
I'm leaning towards option 1. Structurally it sounds like it would hold better? But I've haven't done a lot of welding on frames especially where frame integrity is so important. So I'm asking you guys. Help appreciated.
The bikes one of my dailys, for those interested. Have been procrastinating on hooping her and I decided today was the day. She's 605 bored, hot cam, Showa gsxr front end conversion and a blast to ride.
Offline work9to5
Re: Rear hoop on a cb550
« Reply #1 on: August 07, 2017, 12:25:50 AM »
More pics
Offline work9to5
« Reply #2 on: August 07, 2017, 11:12:15 AM »
Cal, thanks for the advice as always. I'm confident in my weld experience. Not a ton of experience but not a novice. I found it interesting that the frame tube lengths where different and thought I should post about it. I also couldn't find a detailed post about hooping on here so I thought I'd step by step it. To help my process and get some info out there. Going to run a bunch of test beads on the horns that came off to calibrate my heat setting (and wire speed)before doing the actual frame. If we didn't try things we weren't used to doing on the regular none of these engines would be fixed or these beautiful machines restored/created right 👍 I'd appreciate your advice in future posts, going to take it step by step and pic heavy it.
Offline CycleRanger
  • No comment about being an
« Reply #3 on: August 07, 2017, 11:32:59 AM »
Made in a Friday or a Monday.  ;D
Honda was cranking out bikes as fast as they could back in the early '70's.
I'm sure they had a spec for what was tolerable for those tube lengths since the ends weren't exposed.
Offline westhewelder
« Reply #4 on: August 07, 2017, 09:29:22 PM »
As a welder I'm with cal on the welding, but the supplied slugs should help act as a heat sink. As for fit figure out where the seat sit relative to the frame and cut accordingly it actually wouldn't be a bad thing that they are staggering.
Sent from my SM-T377W using Tapatalk
2011 Kawasaki Vulcan 2011
1969 Honda cb750 (project)
« Reply #5 on: August 07, 2017, 09:33:25 PM »
Depending on the tail you are using, the hoop will not likely be seen.
Offline work9to5
« Reply #6 on: August 10, 2017, 12:42:01 AM »
Irish, yeah that makes complete sense the the off set would add support. Didn't even think about that 👍
Sohc, I'm making the pan and seat to fit the hoop. Actually going to do a slim tuck n roll or diamond "brat" and wanted to leave as much of the frame visible as I could. But it will all depend on how this comes out n' cleans up.
I'm in the middle of my work week. Progress to come Friday!
« Reply #7 on: August 10, 2017, 01:53:36 AM »
Unless you have limited travel, the first major pot hole that rear tire hits is going to have some nasty results and likely a wreck.  No room for the tire under full compression.
Offline work9to5
« Reply #8 on: August 10, 2017, 02:07:38 AM »
Where the fender used to sit, was lower than hoop will sit. Had no contact over 4,000+ miles of riding. But thanks for the input
