Author Topic: Cam Shaft  (Read 883 times)
Offline DanJ
Cam Shaft
« on: August 07, 2017, 12:19:13 PM »
Will a 1978 CB750K cam shaft fit the 1973 CB 750K? It's a Different P/N on the honda website
Re: Cam Shaft
« Reply #1 on: August 07, 2017, 12:24:22 PM »
Sure will and you'll probably like the results  ;)
Re: Cam Shaft
« Reply #2 on: August 07, 2017, 12:26:03 PM »
Offline DanJ
Re: Cam Shaft
« Reply #3 on: August 07, 2017, 02:01:37 PM »
Great thanks
Re: Cam Shaft
« Reply #4 on: August 07, 2017, 02:03:24 PM »
+500 rpm redline too
Re: Cam Shaft
« Reply #5 on: August 07, 2017, 08:23:01 PM »
Re: Cam Shaft
« Reply #6 on: August 07, 2017, 08:29:22 PM »
The 78 K had the F2/F3 springs but the F/F1 and the K7 all had the -300 valve springs with the 8500rpm redline. If you can get the later springs definitely do so. Last thing you want to do is float a valve into a piston. The stronger cam will help the top end HP but that COULD bite yer ass depending on how you ride.
Offline DanJ
Re: Cam Shaft
« Reply #7 on: August 08, 2017, 08:41:05 AM »
I take it easy on the CB, if I have the need to get stupid I have a ZRX for that.
