Author Topic: Look what the PO did ×%&*@  (Read 2272 times)
« on: August 07, 2017, 01:25:40 PM »
This I find now, it's going to have to do  ouch !
Offline MoMo
  • Ride like you're invisible
Re: Look what the PO did ×%&*@
« Reply #1 on: August 07, 2017, 01:33:46 PM »
Doesn't look like it would harm anything,  is this the motor for the upcoming reunion tour? ...Larry
« Reply #2 on: August 07, 2017, 02:11:12 PM »
Wrist pin still turn free?
« Reply #3 on: August 07, 2017, 02:31:42 PM »
Wrist pins turn, they are not dents well one prick punch mark, the rest are die grinder bites.
Finally  figured out the POstory. I knew motor was apart.
Smoked like crazy at first, then settled down a bit but slowly increased. At one point ate the cam.
I fixed that. But now I realize,  it must have been seized real bad. And on 2 and 3, they used a diegrinder to get the piston off the rod. It's the only thing I think that could have done that.
 The guy originally offered it to me as parts, but it had reggie.  Now I know why, I think they gave up !
 I will run it, simply don't care..anymore.. want to get to Colorado.
Offline Bankerdanny
  • Endeavor to persevere
« Reply #4 on: August 07, 2017, 02:32:50 PM »
Damn him, building an upside down engine like that. How the heck are you going to fit it in the frame? And chain alignment is going to be a nightmare.
« Reply #5 on: August 07, 2017, 02:40:42 PM »
Oh, I am posting from my new tablet, first time for pics.
When I click on them they enlarge right side up.
 What happens when you click on them ?
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #6 on: August 07, 2017, 02:52:14 PM »
Should be okay for mild street use. Certainly would not want to race it with those rods!
I wonder where all the grinder debris went?  :o  ;)
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline MetroRedneck
« Reply #7 on: August 07, 2017, 02:53:23 PM »
Pics are right side up when opened.
Looks like he made a custom squirt hole cooling mod.
Online Stev-o
« Reply #8 on: August 07, 2017, 03:28:45 PM »
Dont worry, you wont see it once buttoned up!
« Reply #9 on: August 07, 2017, 03:42:59 PM »
Unless it decides to create a new "window"...  :o  ;)
TAMTF...
Wilbur
Projects:
Online Stev-o
« Reply #10 on: August 07, 2017, 03:58:49 PM »
You mean similar to the "window" in my K4, Wilbur?!
« Reply #11 on: August 07, 2017, 04:21:05 PM »
Not helping, ,  scaring me   It will be high compression stock bore. RD 315 cam, Webers I hope
Be  tempting to wring it out,  after Dolores.
Offline gschuld
« Reply #12 on: August 07, 2017, 04:50:51 PM »
Someone should start an engine carnage photo thread...that is a good opening salvo ;)
I've got some pics...we know Billy has some   :o (...running and ducking)
George
« Reply #13 on: August 07, 2017, 05:08:10 PM »
If those pistons were so hard to get off you'd expect galling of the rod little ends??
Offline BPellerine
« Reply #14 on: August 07, 2017, 05:22:55 PM »
Frank,maybe you could smooth off the sharp edges,might help a little bit,at least you got hd studs,if anyone will make it to colorado it will be you!haha bill
1978 CB 750K ard and webers
another anfob
« Reply #15 on: August 07, 2017, 05:29:11 PM »
Yup!
I was thinking the same thing. Sharp edges are often the point of failure.
Damn the torpedo's! Full speed ahead! Seriously though, these old Hondas were overbuilt, so there is a little "wiggle room" built in. Just playing the devil's advocate!  ;)
I'm drag racing a low compression 836cc (flat tops) that regularly mostly sees 9200 to 9500 rpms with stock rods. So far so good!  8)
« Last Edit: August 07, 2017, 05:31:47 PM by madmtnmotors »
TAMTF...
Wilbur
Projects:
« Reply #16 on: August 07, 2017, 07:26:16 PM »
Bill  I never had HD studs neither does this.
My 836 that I ran on and off plus raced a lot had stock rods and cast piston  (think they were RC,s).
 This one was not stuck while I had it, but I knew they were inside it, and they offered it as parts, and I suggested trying to run it, and I did 2 seasons.
Online Stev-o
« Reply #17 on: August 07, 2017, 07:59:56 PM »
Good idea!
Online scottly
« Reply #18 on: August 07, 2017, 08:00:57 PM »
At this late date it might be time to start thinking about the plan "B" motor??
Offline BPellerine
« Reply #19 on: August 08, 2017, 05:03:36 AM »
the pic kind of fooled me,I see now,hope it works out.bill
another anfob
