Author Topic: A Noob's 75 CB550 Cafe Project Thread ------- Stick a fork in it... ;-)  (Read 221291 times)
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
Re: A Noob's 75 CB550 Cafe Project Thread
« Reply #25 on: December 24, 2006, 06:24:53 PM »
       Hey Doug,
                   Great work! Just from what I've seen already, that is going to be one "Fine Looking Ride"
      that you will have created. This looks to be just another fine example of true workmanship  8)
      meticulously applied by someone who truly believes in what he's doing. Keep up the good work and
      I'll catch you later on, Bill  :) ;)
Member # 1969
Offline CrisPDuk
  • Christ on a bike! Me, an
« Reply #26 on: December 24, 2006, 07:13:33 PM »
Merry Christmas all :)
Hot damn, with all this attention to detail your 550's gonna look good 8)
Trouble with all these photo's though is, you're making me miss mine. I won't see it again until May :(
Quick question on the hagon shocks, have you for the stock springing & damping rates, or a bit stiffer?
1978 CB550 K3
1985 H100S
Offline doug_id
    • My Cafe 550 Project Gallery
« Reply #27 on: December 25, 2006, 06:27:11 AM »
Thx to everyone here for taking the time to answer my many questions past and future  ;)
As well as for the compliments and encouragement......  ;D
Merry Christimas,
Doug
« Last Edit: December 25, 2006, 06:54:00 AM by doug_id »
02 Concours
78 CB550
06 Stella 150 2t Scooter
Offline doug_id
« Reply #28 on: December 25, 2006, 06:31:51 AM »
Hi Cris,   Hmmmm not really sure on the spring and damping rates.  The place that I bought them asked me for my weight, riding style, passengers, etc.  They probably used that information to dial those settings in on the shocks.   I did exagerate on my weight some as I prefer a firmer ride.
They did mention that they have been selling a lot of shocks to CB 550/750 owners.
Doug
02 Concours
78 CB550
Offline BARDAR
« Reply #29 on: December 25, 2006, 06:21:16 PM »
Doug if you call yourself a Noob, then that would make me the Ultra-Noob!  Your bike is looking great!  Mine on the other hand is a poor mans job being rushed.  One day it'll be nicer, for now I just want to ride!
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
« Reply #30 on: December 25, 2006, 10:44:01 PM »
Sweeeeeet looking project.  I love the Tomaselli style headlight brackets.  You mentioned needing to get them on before tightening the forks?  Another option, although not as good as putting them on the way you did it, is to slice the rubber sleeve so you can get it onto the fork tubes.
Of course to get the original ears off, you need to lower the fork tubes anyhow, but just saying - it is a way around it.
Can't wait to see more pics.  The added metal to the frame to match the seat looks awesome.  What are you doing for rear signals (what many of us have used those leftover holes in the frame for after removing the rear fender/grab bar etc.)?
Offline doug_id
« Reply #31 on: December 26, 2006, 07:14:52 AM »
Thx Tintin,
Yea, good idea on slicing the rubber that would have made the whole deal easier for sure....they were somewhat hard to get on even lubed up with windex.  I just felt kind of stupid after getting the forks on and tightened down then realizing I had to loosen and lower them again.... ::)
I have two sets of the real small cat eye turn signals.  I was planning on putting them thru the holes that were already in the frame as I have seen others do.  But now that the flat iron is welded over the top of them the bolt on the flasher would not be long enough to go thru both layers.  Now I am leaning towards drilling a hole on the sides of the seat hump and mount them there.   On the front I will probably end up drilling a hole in the new headlight brackets and inch or so back from the headlight mounting hole for the front turn signals.  Then drilling two small holes thru headlight bucket for the wires to pass through.
02 Concours
78 CB550
lendog
« Reply #32 on: December 26, 2006, 10:56:15 AM »
Wow, that's some inspiring work you got going on! That is a sweet seat/tank combo from Benjie. Can't wait to see the finished product. Good luck and keep the pics coming!
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
« Reply #33 on: December 26, 2006, 11:07:40 AM »
Whats the paint/color gonna be on this ride ?
Offline doug_id
« Reply #34 on: December 26, 2006, 12:13:08 PM »
Leaning towards silver or metalic grey on the seat and tank with maybe a couple of black pinstripes or some kind of graphicl.
Doug
02 Concours
78 CB550
Offline CrisPDuk
« Reply #35 on: December 26, 2006, 05:36:11 PM »
Why don't you try borrowing the method JP used on his grass tracker project
http://www.sohc4.us/forums/index.php?topic=16458.0
They look really trick 8)
For my fronts I had a pair of mounting tubes made up with a thread to take the turn signal at one end, and with the same thread as the nuts that hold the head lamp bowl in place on the other, then I put the front turn signals where the big orange reflectors used to be.
1978 CB550 K3
1985 H100S
Offline doug_id
« Reply #36 on: December 27, 2006, 05:32:15 AM »
Hi Chris....thx for the link and the signal ideas....that sure is a nice looking bike.
02 Concours
78 CB550
Offline Dougy Dougy Dune Buggy
  • Wrenchin Mofo
« Reply #37 on: December 27, 2006, 12:54:56 PM »
Doug,
I noticed that one of your "Speedline" rocker adjuster covers is missing?? is there a clearance issue or is it just gone?
not to be one to point out the obvious, just curious, i'm going to bead blast mine and clear coat them after
Later,
DWYJ/The "Other" Doug
I'm going to Cafe it
ONE DAY
ha ha
Offline doug_id
« Reply #38 on: December 27, 2006, 02:13:20 PM »
Doug,
Later,
Yeah....I left the one off as I think it will be in the way of the filter I plan to put on the breather tube outlet.
Just a heads up for everyone that if you get the allen bolt kit and try these alternate rocker adjuster covers they don't play real nice together.   The taller head of the allen bolts will scrape the side of the covers as they get tightened down.
Doug
02 Concours
78 CB550
Offline doug_id
Messing around
« Reply #39 on: December 28, 2006, 07:23:54 PM »
 ::)  ;)  ;D
02 Concours
78 CB550
Offline bill440cars
Re: Messing around
« Reply #40 on: December 28, 2006, 09:21:30 PM »
 ::)  ;)  ;D
                     Oh yeah, nice touch. That is really a cool 8) detail.
                                             Later on, Bill :) ;)
Member # 1969
Offline kuyarico
« Reply #41 on: December 29, 2006, 06:15:21 AM »
I have to chime in here. I think you surpassed the Noob status a while ago. Nice project you got going on in here. I can't wait to see some pics with Benji's seat and tank combo. I was considering the same for my 550K, but my frame and engine aren't clean enough to be worthy of that kind of treatment. Your thread makes me want to strip it down to the frame and do a full resto. Thanks for putting crazy ideas into my head  ;D
Offline doug_id
« Reply #42 on: December 29, 2006, 06:27:20 AM »
Hehe....you are so welcome    ;)
Noob in terms of my mechanical experience.....prior to this project changing my oil and sparkplugs was about it for me.   So this is a mind altering experience.   ;)
02 Concours
78 CB550
Offline doug_id
More Misc
« Reply #43 on: December 30, 2006, 03:26:33 PM »
Got new rubber on the rims(stock size) still need to put in new bearings front and back    :(
Also, started putting the wiring back on with new igition switcn, installed center and side stands, and misc painting.........
02 Concours
78 CB550
Offline scunny
  • don't call me expert
« Reply #44 on: December 30, 2006, 03:35:17 PM »
love the spray booth  ;)
wish you would slow down, you are making my build look pedestrian  ;D
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline doug_id
« Reply #45 on: December 30, 2006, 04:07:17 PM »
Yeah it is high tech for sure.   ;D
I have it in my garage and leave a space heater running on the parts for 15 mins or so prior to painting....as well as running the paint can under hot water for a while.   We are usually in the 30 degree range this time of year.
02 Concours
78 CB550
Offline mcpuffett
« Reply #46 on: December 31, 2006, 07:07:27 AM »
excellent Doug , looking cool keep up the good work and keep the pics posted  ;),     mick.
Offline doug_id
Opinions on paint and graphics
« Reply #47 on: January 01, 2007, 11:12:07 AM »
Getting close to painting my tank, seat, and side panels.
Here is what I am thinking.
Like the grey on this bike....
Then stick one of these spider decals on either side of the tank and then apply a couple of layers of clearcoat....
http://www.reflectivedecals.com/blackwidow.htm
Maybe also so two narow black pinstriping rows down the center of the tank and the back of the seat as well as a single pinstripe border around the side panels.
Thinking that would look pretty nice   ???  ;D
02 Concours
78 CB550
Offline cafe75-550
Re: Opinions on paint and graphics
« Reply #48 on: January 01, 2007, 03:18:00 PM »
Well I for one think it would look pretty good! ;D Nice Duc! Interesting seat on that one...I like how the "hump" is just attached to the back...frame forms the rest? Got any more pictures of that one?
New bike!
'07 Triumph Speed Triple 1050
Never enough projects!
'75 CB550 "Cafe", '76 CB550 parts bike
'64 Norton Atlas featherbed/'71 Triumph 750 Triple (Triton project)
'68 BSA Thunderbolt (frame and cases, project in the wings)
'57 Triumph Thunderbird (frame and mostly complete engine)
Offline doug_id
« Reply #49 on: January 01, 2007, 05:16:39 PM »
Sorry, I don't.  Just a pic I found on Flickr.
02 Concours
78 CB550
