Why are you trying to pull out your needle seats? do you have new needle seat/pins to install?
Those now look too rough to allow the needle to move freely
carb slides look a bit on the high side, but i cant be for sure.
take the same picture, but put a flashlight in the other side of the carb...so it shines back towards the camera.
need to see how much light shines thru.
as far as the slides moving..yes, they should, when you apply the choke.
BUT, you need to make sure teh carbs are bench sync'd first.
once that is done, adjust the fast idle cam screw you pictured above....it needs to be closer to its stop.
